Old 11-26-2007, 10:08 AM   #1
barthmonster
what frame for 4x4 ??
I got my Son and I a '67 C10 Stepside Longbed 2wd (long-step??). He would like it to be a 4x4, the body is rust-free I can't believe it !! So which frame's should I be looking at??
Suburban '67-72 and / or '73-80 ??
Pickup '67-72 (longbed) or '73-80 ??
Any others?? Is the '73-80 a tougher deal because of cab-mounts, etc...??
Thanks guys in advance !! I'm new here and when we start, we'll do a picture-story of the restoration...
barthmonster is offline   Reply With Quote
Old 11-26-2007, 10:27 AM   #2
1969k10stepside
Re: what frame for 4x4 ??
Really,any 4wd 67-72 frame can be used if you can lengthen or shorten the chassis and move body mounts..69-72 4wd frames are better than 67-68s though but the 67-68 frames can be used..73-87 frames can be used too but you have to shorten the chassis if it's a long bed just so your long bed will fit on there w/ out a big gap between the cab and bed.Same for a shortbed,a shortbed 73-87 chassis is longer than a 67-72 shortbed chassis...Same on a blazer chassis too.You will also have to change out body mounts if using a 73-87 chassis,and due to the frame design,will probably have to use a body lift...Easiest way-find a 67-72 4wd longbed chassis..second-find any 67-72 4wd chassis and modify to use.Last resort-find a chassis from a different era to use.
1969k10stepside is offline   Reply With Quote
Old 11-26-2007, 10:33 AM   #3
barthmonster
thanks, that helps a lot.
Old 11-26-2007, 10:43 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Welcome to the board from Seattle. Keep an eye on the forsale sections - the pop up ever so often. Got any pics of the truck?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-26-2007, 10:47 AM   #5
jdstx
jdstx's Avatar
Is the long step wheelbase longer than the long fleet wheel base?
jdstx is offline   Reply With Quote
Old 11-26-2007, 10:47 AM   #6
1969k10stepside
Nope..as long as they are both 67-72 frames.Same frames,same mounts.
Old 11-26-2007, 10:53 AM   #7
jdstx
jdstx's Avatar
I thought I read some where that the long steps were the same wheelbase lenght as the longhorn. I'll see if I can find it.
Old 11-26-2007, 11:04 AM   #8
jdstx
jdstx's Avatar
I found it. The web site is antiquechevytrucks.com. It stated that stepsides were available in 1/2, 3/4 and 1 ton with wheelbases of 116", 127" and 133". If this is correct, the answer is... (yes and no)?
Old 11-26-2007, 11:45 AM   #9
1969k10stepside
There was a 9' stepside bed for the one tons..It was only on the one ton chassis though.There was a short step bed for 1/2 tons (short wheel base),long step bed for 1/2 and 3/4 tons (Long wheel base),and the 9' stepbed on the one tons.The 9' stepbed was longer of course since the one ton chassis was longer.
Old 11-26-2007, 03:23 PM   #10
barthmonster
here are a couple...
Old 11-26-2007, 03:47 PM   #11
1969 GMC
1969 GMC's Avatar
Are you doing pure resto or are you going to take this thing offroading? If you are going with the latter, I would look at using a 73 and up 1 ton 4x4 frame, much stronger than the half and 3/4 ton frames.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-26-2007, 05:50 PM   #12
barthmonster
Just a good 4x4 for a young man. We do want it to last, but it probably wont be off-roaded real hard...
Why the name 'Exxon Valdez', does that Ford leak a bit of oil?? haha?!
Old 11-26-2007, 06:40 PM   #13
jerry moss
Born Psycho
jerry moss's Avatar
personally, i would look for a 71-72 rolling chassis, they have more bracing around the rear spring hangers, disc brakes in front, 205 transfer case all standard equipment. your existing body would be a direct bolt-on. the only body mod you might need to do is a high hump if you truck doesn't have one already--if it's a 4 speed, it'll have a high hump already.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 11-26-2007, 07:10 PM   #14
teeitup
Just like to part out trucks!!
teeitup's Avatar
I PM'd you. I may be able to help. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 11-26-2007, 09:24 PM   #15
barthmonster
This '67 IS a 4-speed and 6-cylinder. And if a larger hump WERE needed, a guy I know got around it with a small body-lift I think 2" is all.
Old 11-27-2007, 08:01 AM   #16
Jerry`s right.Your cab is the same as a 4wd...there are only two types.You`ll need 4wd cab mounts,though.I have a 2wd body on a 4wd frame and only the VIN gives it away.We have a recent resident body-swapper here on the sight.I won`t mention any names,but his initials are JoesJunk.Search his threads and check it out.
These 8' Steepers look great as 4wds.I think there`s a picture "sticky" in the 4wd that`ll have some inspiring examples.
So...you have one of the best RVs ever made?Or,am I mistaken?I think you should show that thing off.BTW,nice find on the`67.
Old 11-27-2007, 10:34 AM   #17
teeitup
teeitup's Avatar
Thanks Jerry, I appreciate it!!!
Tim thats what I told him and also the rad support bushings, while he was doing it.
He's not planning on doing this for for quite awhile though
Randy
1980 chevy swb 4x4
Old 11-27-2007, 10:37 AM   #18
nightmare
nightmare's Avatar
That is a nice truck to start a 4x conversion on. I like the bumper on the back. Do you have any more pics of it? I'm looking for ideas for my truck, when it comes time for the rear bumper.
By the way, hello from down south, Houston, TX.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 11-27-2007, 05:06 PM   #19
barthmonster
Here. What do you like about that bumper, we ourselves were not too impressed with its looks...
A guy here in town has a '67 4x4 and my son (10) loves it. Gotta admit, the truck is kind of long, might look a lot better as a 4x4...
Old 11-27-2007, 05:09 PM   #20
barthmonster
we'res the pics of the longsteps??
Old 11-27-2007, 06:16 PM   #21
teeitup
teeitup's Avatar
Blazerman, has a 69 or 70 LWB step 4x4, it looks pretty neat.
1980 chevy swb 4x4
Old 12-10-2007, 11:02 AM   #22
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Here's a Couple of Long Stepper's that i have Saved. Good Luck with your Project & Welcome From Indiana....................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 12-10-2007, 11:44 AM   #23
72chevy327
Can some one please list the mods needed on a 73+ frame to fit a short box 72. Thanks Quinn.
72chevy327 is offline   Reply With Quote
