Old 11-27-2007, 11:16 PM   #1
samwise68
FarmBoy.
samwise68's Avatar
No Heat?
hey all,
first. i have searched. but was hoping i could find a more specific answer to my question.
on my GMC, there's very little heat. and, since i live in Wisconsin, this is a problem. lol.
after letting it idle for about 10-20 minutes, the vents just don't blow much heat.
the heater core is fine, as both hoses coming to and from are warm to the touch.
so, what can i kinda look at to be the culprit?
a resistor? a bad relay? control panel not opening up all the way?
any ideas would be great.
thanks all!
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 11-27-2007, 11:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: No Heat?
is the problem low air temp, or is it low air flow?
Have you run it longer than that? Tried driving it?
Coolant level good?
Old 11-27-2007, 11:55 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: No Heat?
What thermostat are you running? You say the heater hoses are warm to the touch, but they should be hot.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-28-2007, 12:01 AM   #4
jrdv
jrdv's Avatar
Re: No Heat?
I had the same problem. I switched the hoses and ran the coolant backwards for a short time. It worked-I think the core can get plugged with junk sometimes.
john
jrdv is offline   Reply With Quote
Old 11-28-2007, 07:14 AM   #5
cdowns
cdowns's Avatar
Re: No Heat?
sometimes the heater core is plugged up with 40 years of pine neddles leaves and mouse nests causing no air flow over the heater core if thats the case you'd need to remove the blower and heater core and clean the crap out the box
Old 11-28-2007, 08:30 AM   #6
Premium72
Premium72's Avatar
Re: No Heat?
yup, i just re built all my heater componants, truck was out side for like 30 min or so an i can hear no i have a leaf in my hater box...YAY!!haha..
Premium72 is offline   Reply With Quote
Old 11-28-2007, 08:41 AM   #7
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Re: No Heat?
if your truck is a A/C equipped truck make sure all vacuum lines are attached , in good condition and hooked up correctly and all vacuum diaphrams are still working -mine was a mess
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 11-28-2007, 11:34 AM   #8
72armyswbtruck
72armyswbtruck's Avatar
Re: No Heat?
Leaves are almost always the culprit
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 11-28-2007, 03:43 PM   #9
70GMCer
70GMCer's Avatar
Re: No Heat?
Just replaced my core and for the second time, MICE nests in the duct work and housing. Cleaned it out and also replaced my blower motor and wheel from a 90's crewcap truck. This thing blows some air now......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-28-2007, 04:15 PM   #10
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: No Heat?
I wanna go ahead and chime into this one as well. I posted nearly the exact same topic in the 73-87 forum and didn't get much of a response.
I have a factory AC truck, and the AC blows cold and blows hard out the vents. The heat, on the other hand, barely trickles out. It's really hot, just doesn't have the flow.
Where is the heater core? I'm not much of an HVAC person.
xtreme80 is offline   Reply With Quote
Old 11-28-2007, 05:58 PM   #11
cdowns
cdowns's Avatar
Re: No Heat?
follow the heater hoses from the engine the other end is hooked to the heater core
Old 11-28-2007, 06:29 PM   #12
beautimus
beautimus's Avatar
Re: No Heat?
As one of the guys above stated, it can also be the water side. if you have plenty of air flow and the air is not hot, then the heater core may be plugged up. i have ran into this myself. when the heater is turned off, the heater control valve shuts down the flow of water through the heater core to keep from roasting you during warm weather. so the stagnated warm water begins to let the disolved minerals drop out and deposit on the interior surfaces of the core. given enough time this can totally block the heater core.
another factor is the use of "bars leaks" this is a product that is sold in a lot of auto parts stores that can effectively plug pinholes in radiators. this stuff will get you home but if you use it, you need to flush the cooling system and change the coolant afterwords. i have repaired this issue on several cars by simply using radiator flush and new coolant.
the next culprit is the thermostat. if it sticks in the open position, the water may never get hot enough to heat the core properly. in other words the water does not stay in the engine block long enough to capture all the heat that it can, before it goes to the radiator and gets cooled off again.
Good luck! Tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 11-28-2007, 06:59 PM   #13
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Re: No Heat?
do you have a temp gauge? It should be running 170-180 degrees. If not a stuck thermostat is the cause. Do you have air flow from the vents?
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 11-28-2007, 07:39 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: No Heat?
What about no thermostat? That could do it too...
- Mike -
RIP El Jay
Old 11-28-2007, 09:02 PM   #15
72402
Re: No Heat?
Might just need a new thermostat. I have to run a 195 degree in mine or it won't defrost the windshield.
Frank
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 11-28-2007, 11:05 PM   #16
samwise68
FarmBoy.
samwise68's Avatar
Re: No Heat?
wow, thanks for all the responses guys!
unfortunately, i haven't had a chance to drive it yet. the longest i've had it run is the time it took to time it, idling in the driveway.
so, maybe its not long enough to get warm? idk.
i was just trying to nip the problem in the butt before i started to drive it avidly.
i'll look into these, starting with driving, and letting it run for a while, to see if that helps. which it really can't hurt.
after that, i can start to diagnose it further. but you all are probably right regarding pine needles and junk. so, i should prolly get on that as well...lol.
thanks guys!
-Sam.
Old 11-29-2007, 12:13 AM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: No Heat?
Also check to see that the heater control valve is actually opening.I had one that the heater temp control cable had slipped in the clamp so when you slid the lever over it just barely opened the heater control valve.The hose into the HC was warm but not hot.Once I figured out what was going on I reclamped the cable and all was well.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-29-2007, 12:26 AM   #18
Ilike 72"s
Re: No Heat?
Could be as simple as adding water if it's low. To low--won't flow! Good luck
Ilike 72"s is offline   Reply With Quote
Old 11-29-2007, 12:01 PM   #19
nightmare
nightmare's Avatar
Re: No Heat?
do you have a picture of this area? i think that mine is doing the same thing. not only that, does anyone have a vacuum diagram that i can reference for the vacuum hoses?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
