What fleet side tailgate latches are out their?
Looking for somthing other that chains. Also I would like a center handle for latches if they make such a thing. Any info would be great and pics are alway welcome!
Kevin LFD Inc. |
Between the earth and the sky
Re: What fleet side tailgate latches are out their?
I have these pins in my tailgate, but I want chains as I have nothing to hold the gate up with when it's open.
Chris - 1966 C10 Shortbed Fleetside, 1991 GMC Sierra 1500 Extended Cab, 1993 Blazer Sport 4x4 My other rides: 1969 Chevrolet Impala SS427 Convertible 1976 Dodge Tradesman B200 2002 Nissan Maxima 6 speed 2004 Mercedes Benz CL500 |
Yeh that would be a pain! Nice looking truck. What I am after is a clean looking out side with out any visable latches like the 67 and up. I wonder if I can gut out a 67+ fleet side and make it work in one of these. If not than maybe small bear claws with a center inside latch.
Kevin LFD Inc. |
Hollister, CA.
![]() Join Date: Sep 2006
What I have seen alot of is the use of GM seat belts....on the inside of the gate.
The catch/button part was mated to the bed, and the male part was welded to the gate. Lift the gate up, and it clicked right in. Works pretty good. Then the scissor type hold back was used. That reminds me, I went to a CarShow a while back in Nevada City, and this old guy had a SUPER clean blown 64...and he was so proud of his power tailgate that he had made, (using actuaters)...it was cool, but that stupid thing took a hour to open !!! SlepySal used slide latchs on his truck that worked pretty well too.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I don't know about the latches adn the handle but I have seen people use cables to hold the tailgate when it is open like what is on newer model pickups
#6 | |
Truck Parts Mfg.
![]() Join Date: Jul 2005
Mar-K does offer the folding linkage to hold the tailgate in the open position, and also the spring loaded sliding latches. These can both be installed on the stock tailgate. Our latches can be latched in the open position so you can close the tailgate then release them to hold the tailgate closed, two hands not required. http://www.mar-k.com/installation_hints.html and scroll down to "hidden latch instructions" and "link assembly instructions" We are developing a replacement tailgate for these trucks with a center handle and "bear claw" type latches. This will be similar our stepside tailgates with the latches and handle. We hope to have these available in 2-3 months. These will have that "click" that you desire. Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
I bought a pair of manual dead bolts for a for a regular house door. They are called barrel bolts, and you have to install them on the inside of the tailgate. Only problem is you will have to shade tree some kind of piece to hold the tailgate up when you open. I am not sure, but you might want to check a 67 hardware[hinged] to see if it works. oh, i bought galvinized barrel bolts, look much nicer. I will take some pics and post them.
john |
SIR
...hope some of this helps,all easy to do ,questions,just ask....
66long low fleet http://community.webshots.com/user/LVNR66 |
here's mine, just a later model setup extended to fit our tailgates. Latch is centered on the inside.
![]() ![]() ![]() Last edited by fchava; 11-29-2007 at 10:50 PM. |
SIR
...the latches are from "brothers" and the cable came from "auto-zone",just lay the tailgate down flat measure from the existing bolt holes I think these where fo** but it does not matter then trim out the inside edge of the tailgate grind down and weld the seam closed grind to taste the pins come with easy instructions you just need a drill a die grinder and a small stack of round washers welded together to the inside of the bed,for the "latch to attach"..just takes time.OH the bolts are fine thread.
#11 | ||
Thanks for the motovation Kevin LFD Inc. |
As I said, mine is just a stock unit turned around.
![]() ![]() Sort of rough, but works great ![]() |
Easy Does It
check out mar-k.com they have kits for this. Sir with the green truck could you tell me what you used? thanks
Someone on here is using later model nissan latches and straps on a stepside. That might be something to look into aswell.
Didn't you use something like that on Lemondrop? Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
#15 |
Frank~ Lemond drop had a kit from Mar-K that was the sissor hold opens but used the spring loaded pins on each side. It worked well but took two hands and you could not just close the gate and walk away. Like I said on this truck I want that "CLICK" feeling.
fchava~ Very clean truck! Any links to your truck I can check out? Kevin LFD Inc. |
#16 | |
http://www.picturetrail.com/fregon ![]() |
#17 |
Ok I remember now. What about wondering around a junkyard looking at different tailgates? Could look at all the options at once. Foriegn and domestic setups, I'm sure something will jump out at you as a good plan on what your looking for.
Btw,,, I'm headed to the jy this week end if you want me to look at those hinges, let me know. Frank
#18 |
![]() Join Date: Oct 2006
This is what I came up with cheep and easy
http://67-72chevytrucks.com/vboard/s...light=tailgate
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#19 | |||
![]() I was talking with Stan down at ECE today (he is one of my local guys I call while sitting in trafic ![]() ![]() Quote:
Kevin LFD inc. |
#20 | |
I'll drop you a pm this weekend with what I picked up. Frank
#21 |
I had the "no chains" look with the "seat belt buckle" latches on mine. Never liked to looks. I picked up a tailgate with chains a couple months ago, and went back to chains. Just call me "old school", but I like the looks of the chains.
