11-30-2007, 04:50 PM | #1 |
Alright Alright Alright
knocking coming from the front wheel
today i just put a brand new set of wagon wheels and 275/60/15 tire on my truck. i took it down the street and i started to hear and feel a knocking sound coming from the front passenger side wheel. when i applyied the brakes, it stopped and smoothed out but it would start again when i let off the brake. like i said, the wheels and tires are new. i also changed the wheel bearings a few weeks ago, but there was none of this going on. could the lugs be loose? what do yall think?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
11-30-2007, 05:13 PM | #2 |
Re: knocking coming from the front wheel
The lugs would be my guess or a wheel bearing. Since you just replaced the bearings check the lugs first.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
11-30-2007, 05:13 PM | #3 |
if you think lugs are loose take lug wrench and tighten
jack up that wheel use jackstand and grab tha tire and twist and turn and see if something is hitting or loose// did you use a cotter pin when you did bearings, is there clearance between tierod and wheel ,is there clearance between control arms and wheel, is there clearance between tire and fender
11-30-2007, 05:37 PM | #4 |
i used a cotter pin. i did remember trying to spin the rotor around with the wheel off. i was hard to turn in one spot and then it would spin around till it got to that on spot again. ill give it a look.
11-30-2007, 05:45 PM | #5 |
If you have disks could be the pad hitting a high spot on the rotor making it make a noise.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
12-01-2007, 10:52 AM | #6 |
Is it knocking on turns or on straightaways too?
12-01-2007, 11:34 AM | #7 |
Why don't you jack the front of the truck up and spin the wheel? You should be able to find the noise like that. You didn't tell if it is drum or disc. Check the back spacing and the wheel run-out. Look for shiny spots also.
12-01-2007, 02:59 PM | #8 |
well it was some loose lugs. i was distracted by a phone call and must had gone on to a diffrent wheel. i tightened the lugs, problem solved. thanks for the input.
12-01-2007, 03:19 PM | #9 |
HERE.......Somewhere
If you over torque it you might have made it to tight so you might would want to get you a torquer that beeps we have one in autotech and we put the nut on with our fingers so it wont cross thread and then we use the air gun then we tighten with a torquer. hope theres some mechanics on here that can tell you cause its kinda hard to explain
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
12-01-2007, 06:53 PM | #10 |
Overdrive club
DOHHH!!!!!!!!!Glad ya caught it!!!!!!!!!!!
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
12-01-2007, 06:55 PM | #11 |
time to pull everything back apart ASAP
I BELIEVE IN JOHN 3:16 |
