Old 12-01-2007, 12:15 AM   #1
OldCreek
OldCreek's Avatar
Ease my Hub-Centric whoa's...
Well, I'm gonna get these turbines from a friend for free. But, they're from 'those other guys' and have a 5" opening. Hub-Centric GM wheels are roughly 4 5/8 (corrected me if I'm wrong). (I've also a Chrysler spare that has a 4 3/4 opening.)
Do the Ford hubs bear the weight, i.e. hubcentric, at that size (5")? I think that the hub sizes are roughly the same as GM? Thats how Ford/Dodge D60 axles can be used on our trucks. If not hub-centric, then the lugs must carry the weight. So then, why can't these safely be used on GM hubs?
Or, is it more a matter of centering these wheels on a hub that is smaller than its' opening? These turbines have a flat lug nut surface. The Chrysler spare and GM spare (both steel) have beveled lug nut surfaces... I suppose these are for acorn style lug nuts?
I just wanna use these wheels!
Old Creek
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 12-01-2007, 12:30 AM   #2
Blue_71
Bloo
Blue_71's Avatar
Re: Ease my Hub-Centric whoa's...
if im not mistaken, the correct lug nuts for those have a shank that goes down into the lug hole, which carries the weight and centers the wheel. then the washer/nut holds it tight to the hub
like these:
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-01-2007, 02:35 PM   #3
68K20 x Drill
And you can go into any big tire and wheel store, and ask them for 'hub centric rings'.
I had some custom made for running BMW wheels on my Firebird, and it took such a long time, they felt bad and gave em to me for free.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-02-2007, 12:51 AM   #4
OldCreek
OldCreek's Avatar
hub-centric rings..... interesting!!!!
Old 12-02-2007, 06:45 AM   #5
Blazer1970
Blazer1970's Avatar
The lug nuts will center those wheels OK as long as you have the correct nuts with the right taper for the wheel.
Blazer1970 is offline   Reply With Quote
Old 12-02-2007, 10:38 AM   #6
LONGHAIR
With an 8-lug wheel, I wouldn't sweat it at all. The shank of the nuts will center the wheel and 8 studs are plenty to hold it on.
LONGHAIR is offline   Reply With Quote
Old 12-03-2007, 07:15 AM   #7
They only ever sold custom wheels with a one size fits all center.We never gave it a second thought and I`ve never had a problem or know anyone who has with it.
Old 12-03-2007, 09:16 AM   #8
JAKES 68GMC
Aluminum slot wheels rule...
Yeah, just bolt them up and be happy.
JAKES 68GMC is offline   Reply With Quote
Old 12-03-2007, 11:35 AM   #9
OldCreek
OldCreek's Avatar
Yeah, the more reading I do on the web the more I find that the hub-centric wheels were mainly to CENTER the wheel on the hub, not to carry the weight. Other, 'lug-centric' wheels are centered by the lug nuts. Hub-centric rings are made with plastic, some aluminum. They are used to center the wheel. Don't know if the GM wheel was specifically manufactured to carry the weight.
I can't imagine a reasonable load snapping 8 lugs a side. For example, 8,000 lbs would be 500lbs on each lug.... I wouldn't think that would be enough to shear the lugs.
Old 12-04-2007, 08:54 AM   #10
scotto0609
Junior Member
When you do bolt them up do NOT forget to retorque the bolts after a few hundred miles.
scotto0609 is offline   Reply With Quote
Old 12-09-2007, 02:31 PM   #11
70rs/ss
70rs/ss's Avatar
Most after market wheel have the center opening bigger than the hub, that is how the center cap fits. On an 8-lugger don't sweat it!! I'd love to have a set of those on my 07 dodge, except they need to be 17 in diameter to clear the brakes!
70rs/ss is offline   Reply With Quote
