Old 12-06-2007, 05:25 PM   #1
Mondo
Mondo's Avatar
power steering box
I'm changing it out (leaks like crazy). I've only put in power steering sealing fluid. What type power steering fluid do our trucks take? Should I go with royal purple or some syntec type?
Mondo is offline   Reply With Quote
Old 12-07-2007, 08:05 AM   #2
chris71
chris71's Avatar
Re: power steering box
i dont think synthetic or fancy ps fluid is worth it, unless you have expensive road course racing inspired gear box and ps pump. guys out there are still running the factory original ps boxes and pumps with normal fluid that probably hasnt been changed all that often over the years. in my opinion if you are using the truck for normal useage, as long as your pump and box are in good working order, new hoses clean fluid, no leaks, you will be completely fine with performance (dont forget tie rod ends, pitman arms and stearcolumn stuff as well). i'd probably spend the extra money on getting new tie rods, or more grease to grease everything up. i just use the normal ps fluid for gm vehicles that i get at the parts store. if you do decide to get the synthetic, just make sure that it will be compatible with the new box and old pump. i know with brakes, if you convert from oem to synthetic fluid, you have to change the brake hoses, and all seals in the mc/cylinders/calipers. good luck man, oh and dont forget to bleed the box/pump once you put it on.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 12-07-2007, 08:17 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
I use Pyroil, it's made by Valvoline and is about 50 cents cheaper than Prestone. Both have the same Mil-Spec number on the back, so the rest is marketing. I agree with Chris71, the fancy stuff is for dudes with more money than brains.
'68OrangeSunshine is online now   Reply With Quote
Old 12-07-2007, 11:17 AM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
i use synthetic when i install a new ps box and pump. The way I see it, you change ps fluid so rarely, you might as well give it a bit of a better chance to live a long life. It is 75% more $ wise, but as long as it doesnt leak, it's going to be in there for a while... If either of the two parts is used, go regular fluid.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 12-08-2007, 02:24 AM   #5
wibilly
wibilly's Avatar
up until the last couple years i used tranny fluid now that i buy ps fluid for some of my newer junk i been using it in everything but see no differance other than it costs more
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-08-2007, 05:48 AM   #6
'68OrangeSunshine
Ever wonder what would happen if you put PSF in a TH350?
Old 12-08-2007, 05:33 PM   #7
Mondo
Mondo's Avatar
Thanks guys, I've pretty much replaced all the front end components and this is the last (no more oil leaks). Just wasn't sure if it was the same fluid that's in the automatic transmission... I'll check out the Pyroil.
Any idea how much it'll take? If it's not that much than it really wouldn't matter as it's likely not to be messed with for quite some time
Old 12-09-2007, 04:11 AM   #8
'68OrangeSunshine
Two or 3 quarts should fill the pump. lines and gearbox. Get 4 so you can use some to flush out the system.
