Transfer Case Oil ?
Does the transfer case on an automatic truck take auto trans fluid or gear oil? I cannot remember.
Thanks,
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Re: Transfer Case Oil ?
gear oil. the t-case gets atf in it when the adapter seals go bad.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
![]() Join Date: Apr 2000
what he said..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
ok thanks, just was thinking I had taken some apart from automatics that had all trans fluid in them.
Not a bad nut after all..
Although not ideal, would ATF still work in the transfer case?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
![]() Join Date: Feb 2001
I use 10w40 in my 203 and always have with no problems.
GM started to spec ATF for the NP205 behind automatic trannies in later years. ATF will work just fine in a 205.
Tim |
