Old 12-13-2007, 11:49 AM   #1
cstm68
cstm68's Avatar
saginaw 4 speed linkage.
i have a saginaw 4 speed (car style) that i am putting into my 68.
i am using this shifter
http://store.summitracing.com/partde...5&autoview=sku
i have all the linkage hooked up to the tranny out of the truck to mock it up. it will shift into all gears but it is hard to do and i wants to shift 2 arms at one time.
it shifted fine with the original camaro linkage but that wont fit in the truck.
mabe i have somthing backwards ?
does anyone have pics or some tips of haw this lonkage should be set up??.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 12-13-2007, 04:28 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: saginaw 4 speed linkage.
I don't have the answer you're looking for, but here's what I had to do to make something work that hadn't been available.
I put a Saginaw 4-speed from a Vega (I believe) into my '81 El Camino. I bought a Hurst Indy shifter that was supposed to be correct for the transmission. However, the stick was short, like six inches long. It bumped the bench seat in the truck. So, I went to my Hurst catalog and started looking. I found a shifter handle that would bolt to the linkage and clear my seat. What started out as a $100 shifter became a lot more expensive when I had to special-order the stick. But, it looked good, and worked right.
Member Nr. 2770
Old 12-13-2007, 05:16 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
I have had bad experiences with cheap shifters. many times there isn't much room between the gates. a quality unit should fix it. or better yet, make a new handle for the old shifter.
68C15 is offline   Reply With Quote
Old 12-13-2007, 10:10 PM   #4
jimfulco
Look at the instructions real close, and make sure the shift rods are facing the right direction, and that they aren't interfering with each other. Putting the front rod ends in the shift arm holes closest to the pivot point will give you a shorter throw, but it does make it harder to shift.
See if there's any way to loosen the grip the big central through-bolt has on the shifter levers so they don't bind and try to move together, but without making the whole shifter loose on its mount. Might also have to over-ride the "dry film lubricant" with some spray lube such as BreakFreeCLP or TriFlow. They didn't have dry film when I had mine, so I had to hose it down with oil once in a while.
Also, be sure your clutch is adjusted properly so it will completely disengage when the pedal's down. If it's still slightly engaging, it will be hard to shift.
jimfulco is offline   Reply With Quote
