Old 12-13-2007, 05:02 PM   #1
BP68
BP68's Avatar
BP68 Official Build Thread
Hey all
When I was new to the forum I started a couple different threads detailing the frame up build of my 68 C10. I am now compiling my past progress pics into the Projects and Builds sub forum. All updates will be posted in this thread. Enjoy.
Here is what I started with. I first bought the 68 shortbed 307 3spd not running. Front drums, no power steering or brakes, 6 lug. Over the next couple of years I found a shortbed frame that already had 5 lug discs and had been cleaned and painted. Then I found the cab has some hard to fix issues and picked up the 72 Long bed factory air parts truck. It had been a daily driver untill someone pulled infront of the previous owner. I got everything but the damaged front sheet metal, eng, and trans.
Name:  1st truck.jpg
Name:  1-truck stripped.jpg
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-13-2007, 05:12 PM   #2
BP68
BP68's Avatar
Re: BP68 Official Build Thread
I also got a Throttle body 350 out of a 89 Suburban that my father in law wrecked due to a tractor trailer pulling out in from of him. I kept the stock short block because it was only about a year old crate motor. I added cast iron Vortec heads, a Comp Cams 12-211-2 camshaft (224/224 .470/.470 110 lobe sep.) a Edelbrock 350 carb and Vortec intake, chrome timing cover, HEI, and Sanderson ceramic coated headders (highly recommend) plus the factory serpentine setup. Estimated around 300 - 330hp.
03 Grand Prix GTP
Old 12-13-2007, 05:18 PM   #3
BP68
BP68's Avatar
A few more engine pics
03 Grand Prix GTP
Old 12-13-2007, 05:27 PM   #4
BP68
BP68's Avatar
Next up the extra chassis I picked need a fresh coat of paint after sitting and being in storage. Plus I had a ECE 4/6 drop kit to install. We used cast iron engine enamel on the steering gear, front brakes and spindles, and the center link and tie rod ends. This got topped with a little high temp clear. The suspension got hammered silver metal paint. The trans and gas tank got an aluminum color and the driveshaft is also the cast iron color.
03 Grand Prix GTP
Old 12-13-2007, 05:29 PM   #5
BP68
BP68's Avatar
By the way, that is gloss chassis saver black on the frame. I think it is used for semi trucks. We actually brushed it on and it leveled out pretty nicely.
03 Grand Prix GTP
Old 12-13-2007, 05:34 PM   #6
BP68
BP68's Avatar
And finally the body. Shaved drip rail, cab seam, door handles, wiper cowl, tailgate handle, and rear cab light. The firewall got smoothed and the center of the dash is also smooth. I will be adding a/c controls and a billet center a/c vent. Thinking of putting the radio either in the glove box or under the a/c controls. Also picked up new 67 fenders and cowl hood from LMC. The cab is off the 72 long bed, the grille panel, core support, and doors are off the first 68. When I get to the bed, it will also be from the first 68.
03 Grand Prix GTP
Old 12-14-2007, 08:25 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I think your door gaps are damn sure on the money. Good job.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-14-2007, 11:32 AM   #8
b&a72
Active Member
b&a72's Avatar
Looks awesome so far. Are those the headers from ECE? And how good is the EZ Harness does it have the ignition for the dash, and all the goodies the painless comes with.
b&a72 is offline   Reply With Quote
Old 12-14-2007, 02:51 PM   #9
BP68
BP68's Avatar
The headders are the Ceramic coated Sanderson's from ECE. In a couple of the pics you can see the longtube headmans I had. The fit was awful and the finished dulled while the truck was stored. Had not even run em.
The EZ harness I got off ebay came with a 21 ckt harness, the following switches (ign, headlamp, wiper) billet knobs for all the switches, headlamp connectors, turnsignal switch connector, varaious terminal ends, fuse link wire, and some zip ties.
03 Grand Prix GTP
Old 12-15-2007, 05:54 AM   #10
b&a72
Active Member
b&a72's Avatar
Did the harness come with the AC wiring as well?
Old 12-15-2007, 08:02 AM   #11
BP68
BP68's Avatar
Did the harness come with the AC wiring as well?[/QUOTE]
I beleive it has the wiring for fused power, and for running to the compressor clutch.
03 Grand Prix GTP
Old 01-17-2008, 11:37 AM   #12
6T9GMC
6T9GMC's Avatar
Man That Looks Good. I Didn't Know How Everyone Cleans Up The Pieces They Weld In, Like On The Firewall Stuff.i Know You Use Bondo To Finish It, But I Didn't Know How Far To Finish The "metal" Part Of It. It Looks Awsome!
6T9GMC is offline   Reply With Quote
Old 12-15-2007, 12:08 AM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Looks great! I love the shaved driprail. Where are you gonna mount everything that used to be in the dash?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-15-2007, 08:01 AM   #14
BP68
BP68's Avatar
For now I am thinking of mounting a dual outlet oval billet center a/c vent about where the stock one was, then put the billet a/c controls below it, and maybe the radio on the battom. I never really planned to leave the dash completely shaved, just wanted to smooth out all the steps and dimples.
Here is the a/c controller I plan to use. I will see if I can find a better pic.
This the link to the system I am planning on right now
http://www.classicautoair.com/Custom.asp
03 Grand Prix GTP
Old 12-15-2007, 04:01 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That thing is beautiful! I can't wait to see the end result...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-15-2007, 05:50 AM   #16
lks dcvn
lks dcvn's Avatar
I think it looks awesome - can't wait to see how this turns out.
Keep the info and the pix coming.
lks dcvn is offline   Reply With Quote
Old 12-15-2007, 07:45 AM   #17
Frizzle Fry
Frizzle Fry's Avatar
Nice work!
Frizzle Fry is offline   Reply With Quote
Old 02-14-2008, 01:24 PM   #18
franky69c10
chevy runs deep
franky69c10's Avatar
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-14-2008, 05:28 PM   #19
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Very cool build,definitely keep progress pics coming. I like what yur doing so far and the mods are turning out nice. I have a few engine choices but if I find a used later model ls2 or similar I think I will make a swap.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-14-2008, 11:50 PM   #20
BP68
BP68's Avatar
Thanks for the feedback all. I am so anxious to get this truck done. And I sure wish I could do paint and bodywork. I am waiting on my bodyman right now. I plan to get some wiring done in the next few weeks, but the next big step is getting the cab and front end aligned and painted. I will post more pics as soon as I get something done.
03 Grand Prix GTP
Old 02-15-2008, 02:27 AM   #21
Hart_Rod
Hart_Rod's Avatar
Beautiful truck, keep plugging away, you're almost there, .
Hart_Rod is offline   Reply With Quote
Old 02-15-2008, 02:39 AM   #22
lumpy81
lumpy81's Avatar
Lookin good, you'll have yourself a sweet ride.
death metal and hotrods
68 GMC SHORT STEP
35 CHEVY PICKUP
A FEW BIKES
SINNERS C.C.
lumpy81 is offline   Reply With Quote
Old 02-18-2008, 12:54 PM   #23
MisterE72
Keep Your Nose Clean
Have you been able to keep the overspray off your engine, suspension, and frame? If so, how did you do it? I'm worried that all my hard work on the chasis is going to go to waste when the painter gets a hold of it.
MisterE72 is offline   Reply With Quote
Old 02-19-2008, 11:40 AM   #24
BP68
BP68's Avatar
Thanks for the compliments all
As far as overspray. The firewall was painted before the cab was set on the frame. Any further painting will just require careful masking of the frame/eng/etc. to keep the overspray off. My bodyman is a close friend of my Dad-in-law and does some top notch work, so I am not too worried.
03 Grand Prix GTP
Old 04-01-2008, 06:59 AM   #25
BP68
BP68's Avatar
Well, I am getting tired of all the waiting around for paint, so I am thinking of bringing the truck home to my garage for everything else.
I plan to get the steering column mounted and hooked up, mount up the Booster and master cylinder and finish up the brakes. 2 fuel line connections and some wiring, and a quick trip to the exhaust shop should get me running, driving, and stopping.
When I pick the truck up, I will prob drop the bed off with the body man, so maybe it can get some prep work while I do my stuff. Then maybe I can join the main truck back with the bed and get the paint done. Last to go in is the interior, and a set of wheels when money allows and hopefully I will have a nice truck to show and enjoy after all these years.
Sure wish I knew body and paint. If I did, I would prob finish it all myself.
Hope to post some progress pics within the next month. Stay tuned
03 Grand Prix GTP
