Old 12-14-2007, 04:49 PM   #1
kamikazekyle05
kamikazekyle05's Avatar
Tach Help
Hi yall, i just got my truck, and it already has a tach in it, it worked but since has stopped, the external regulator? went out on the truck right before i bought it, dont know if that has anything to do with it, any help on what might be the problem or where to start looking, Thanks Kyle
kamikazekyle05 is offline   Reply With Quote
Old 12-14-2007, 05:39 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Tach Help
Need more info. Is this a stock in dash, or aftermarket tach? Are all the wires hooked up? Also need to know how it is wired. Is this an HEI, or coil truck? Where is it powered from? Fuse box? More info please.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-15-2007, 02:49 PM   #3
kamikazekyle05
Re: Tach Help
Sorry its stock tach(or aftermarket from lmc but stock lookalike), i tried tracing the wires today, started at the distributor, followed through the firewall, to the fuse box, then it looks like its spliced and then i couldnt follow where it goes
Old 12-15-2007, 03:51 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Tach Help
so it doesn't work at all? Then I'd remove the wire at the coil and totally clean up the connection and re-install,as a first step.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 12-15-2007, 07:27 PM   #5
red71cheyenne
Back in the sticks
Re: Tach Help
Pink wire should go to a pink in the fuse box and the brown goes to the tach lead on the HEI. If you don't have an HEI, it goes to the + on the coil. If those are hooked up, you may have a bad tach.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-16-2007, 01:41 AM   #6
byrd
Union Electrician
byrd's Avatar
Re: Tach Help
The brown signal wire goes on the Negative side of the coil, when not using HEI.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-16-2007, 04:22 PM   #7
kamikazekyle05
Re: Tach Help
Thanks guys, ill try pullin the wire and re installing, and see if i get anything, on a side note it is a hei, cuz the brown wire goes to the tach lead, and the pink to the fuse box
