12-17-2007, 11:25 AM | #1 |
The Crazy Machanic
Need help with tbi stuff (fuel pump)
Im working on my cousins 1988 k5 blazer 4x4 it has the tbi set up and she not gettting fuel to the system. My first thought it fuel pump in the tank, which is still an option becasue i can not hear it running. UN screwed fuel turn truck on and got no fuel. But im looking for one thing before i go dropping this tank.. Where is the fuel pump relay (autozone sells it but i have no idea where its sitting. also if there is a fuse for the pump anywhere.
IM at a loss all my trucks are mechanical and only had one like this and never had a issue from it any help would be great thanks.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
12-17-2007, 01:33 PM | #2 |
In the Forgotten far North.
Re: Need help with tbi stuff (fuel pump)
I'll check my wiring diagram when I get home from work tonight and let you know what I find.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
12-17-2007, 01:43 PM | #3 |
The relay should be on the firewall, passenger side, should be gray or black in color. the fuse moves around based on the year. I have seen them right next to the relay have also seen them in the main fuse block. To figure out what you need to fix first find the relay. unhook the wire loom and check for power. If you have power then the fuse is good. next I would put the new relay on it and see if it works. (you can't loose here. if the pump is bad you have to replace the relay) If it does then you were lucky enough to have just fried a relay. if not then get ready to drop the tank. One thing to remember is that most electric fuel pumps die because the fuel filter is plugged.
12-17-2007, 02:21 PM | #4 |
The Crazy Machanic
(i went out to the store to night bought a new fuel filter, pump, strainer , and relay. figure at most i can return what i might not need.
this truck is my cosins and right now im going y must i know these truck from back of my hand. (yet when tbi come to hand i kinda loss my hand that im delt so thx for the help)
