sealing the rain channel
this may be a dumb question but i need to seal the rain channel on my truck. I've got the seal but how wide a bead of this do you normally use? any help is appreciated.
Active Member
![]() Join Date: Jul 2007
Re: sealing the rain channel
As long as you clean out all of the grime and make sure you don't have any rust left, it's really your call.
I caulked mine with a single, thick bead and then used my finger to smooth it and curve it for the water to drain evenly out of it. I just made sure that all of the seams were covered then primed and painted it... |
Saving 1 truck at a time!
There is also a two part epoxy sealer that works really well. Check at your professional body shop for that product. You will also need a special application gun to apply this material. It hardens unlike the GM drip rail caulk.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
I have to do that too. Clean it really, really good, because any rust left at all will grow fast - figure about every night you get standing water there, from the dew. There's a special caulk to put there, like stllookin says, you can get it at an auto paint shop.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
I used the 3M product, I believe it was #5803 or 5308, not sure which. But it is a self leveling sealer and does a great job. You will need the special applicator gun that some paint suppliers will let you borrow if you buy their product. If you use auto body caulk it won't stay. Here's how mine turned out...
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! Last edited by Botietruck; 12-18-2007 at 02:38 AM. |
