Old 12-22-2007, 02:30 PM   #1
ole school
ole school's Avatar
question about rear ends
i have a 68 gmc truck with no rear end in it i was wondering if a chevy one would fit or what can i bolt up to it without trouble
IT'S HARD TO MAKE CHICKEN SALAD WHEN YOUR USING CHICKEN S.........
1968 crew cab build (under construction)
ole school is offline   Reply With Quote
Old 12-22-2007, 03:13 PM   #2
jkade
jkade's Avatar
Re: question about rear ends
Is is a coil spring set up? If you were closer I would give you one I have out of my 67.
jkade is offline   Reply With Quote
Old 12-23-2007, 02:15 AM   #3
It`s probably leaf,right?It it was coil I may know why it`s gone.The GMCs had a tough little Dana60 6-lugger that`s the toughest rear you can bolt into the coil-rear trucks.Leaf was standard on GMCs with coils an option.The opposite for Chevys.If you have trailing arms(coil)you can bolt any 67-72 coil rear in.If you have leafs you can bolt any 67-72 rear in.You can use later GM 12-bolts but will need to relocate the spring perches for leaf or coil and provide mounting for the track bar.
Old 12-23-2007, 03:41 AM   #4
Huck
Huck's Avatar
Let's get specific---1/2 ton or 3/4?? 2wd or 4x4?? Coil or leaf? You can bolt anything to anything but if you want it to work well, well----what is your truck?
Huck is offline   Reply With Quote
