Old 10-13-2002, 09:27 PM   #1
Rod
Dana 60's power lok vs maximum traction
Seems that the dana 60 came with either a power lok or a maximum traction option availability. What's the option number for maximum traction in a 3/4 ton...G80? Who has more info on a power lok...looking for more info. Maximum traction has spring kit and clutches.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-13-2002, 10:45 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My 70 has the max traction option listed, and I've identified it as a spicer powr-loc. I obtained a service manual from drivetraindirect for a dana 60/70 powr-loc. I don't believe there was two different traction aids available in the dana60. Of course the 10/12 bolts came with a type, and the eaton ones had detroit lockers also called no-spin. Hope this helps. I'm at work I'll be able to check the glove box door around 0030 for the RPO code.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-13-2002, 10:57 PM   #3
Rod
Well I have a dana 60 from a 71 GMC 3/4 ton that has a clutch pack posi ... and I think it said maximum traction on the id sticker when I got that one. I have a power lok from a 71 3/4 Chev this past weekend, option G87 I saved the sticker from that glove box... and have a couple detroit lockers ( no-spin ) from eaton - corporation rear ends option G86. I cant remeber what maximum traction was and are they just clutch pack posi's in 3/4 tons. My GM overhaul manuals have decent exploded pic of power lok but does not show a 3/4 ton clutch pack posi. Parts books dont list a maximum traction option number either.
Old 10-14-2002, 01:20 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Just checked mine G87 -max. traction R axle. It's the powr-loc w/clutches. In my signature, under My 70 GMC, I have scanned in the powr-loc manual.
Old 10-14-2002, 07:40 PM   #5
Rod
Hmm interesting and good scan pics there ... Thanks. Anyone else have a different type posi in their 3/4 ton truck.... I still have one that looks like a 1/2 ton one with the spring kit and clutch packs. Anyone have one like that.
Old 10-14-2002, 09:19 PM   #6
roger0080
Let's see here...
From the GM Parts Book:
G80 Rear Axle - Positraction
G86 Rear Axle - No Spin
G87 Rear Axle - Power Lock
G80 is for the 1/2 Tons.
G86 for the Eaton 3rd member...
G87 is for the Dana 60's
The Chevrolet Overhaul manual says that there are four optional Positraction differential units: Chevrolet (8 1/2" Ring Gears), Eaton (car & truck), Borg Warner (probably cars) and Dana PowerLok. Also says that No Spin was optionally in stalled in 5200 or 7200 lb. axle housings. Only thing it says about the Borg Warner is that when it wears out it must be replaced with either a Chev or and Eaton Positraction Diff unit.
If it isn't the No Spin you must have the PowerLok. Check the Overhaul manual, it has exploded pics of the Eaton Posi, Chevrolet Posi, PowerLok, and the NoSpin.
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 10-14-2002, 09:32 PM   #7
mikep
Used to have a truck
mikep's Avatar
I have a detroit locker in my Dana 60 and its the 2nd Dana 60 with a detroit locker differential I have owned. The first being out of a 69 Charger. This locker unit itself is date coded 1962 . Had no idea they made them that far back. I have no idea what it came out of but its a 30 spline unit and was in a 8 lug rear end sitting in a pile in the junkyard. Iv'e used clutch type and lockers in 9 inch ford and dana 60's and to thell you the truth I prefer clutch type. I cant hear this one engage and disengage but I can feel a bit of clicking around very tight corners or when doing U turns. It grabs like a son of a ***** though !
No truck :-(
mikep is offline   Reply With Quote
Old 10-14-2002, 09:41 PM   #8
Rod
Yep... that info I knew... still is there any spring pack posi's that look like the 1/2 ton posi's in anyones 3/4 ton?
Old 10-14-2002, 09:51 PM   #9
mikep
mikep's Avatar
Oh I get it . Your'e asking if Dana's or Eatons came with GM style coil spring posi's. Dana's have springs but theyr'e bellville type not coil type. Since the only thing that 3/4 tons came with were Dana 60's and Eatons the answer would have to be no. Remember that Dana and Eaton were outside contracters with their own systems. Later 14 bolt GM corporate positraction may have been the same. Never had one apart.
No truck :-(
Old 10-15-2002, 11:29 AM   #10
williso
Here's a page from Dana's own publication # x510-8 dsd which covers their axles from 1967-78. However, if you read the various charts in the book, ONLY the Powr-Loc was available on Chev C20/GMC 2500 for the 67-72 period. The Trac-Loc was used on vans in 74 and later.
williso is offline   Reply With Quote
Old 02-26-2011, 11:10 PM   #11
teeitup
Just like to part out trucks!!
teeitup's Avatar
Re: Dana 60's power lok vs maximum traction
Here ya go Ernesto. THANKS to Chipflyer for finding it for us. Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 02-26-2011, 11:32 PM   #12
otsenre
otsenre's Avatar
Thanks to Randy and Chipflyer for finding this thread. I have a maxi tract r axle on a 68 3/4 ton pickup I am parting out and have never heard of this differential before, again muchas gracias, Randy and Chipflyer
otsenre is offline   Reply With Quote
