Old 12-24-2007, 12:45 PM   #1
VROD383
VROD383's Avatar
Putting in a vortec
I have a 70 blazer and putting in a 98 350 Vortec with the fuel injec. system.
Has anyone have any tricks or info about the wiring and cpu.
Im putting a 700r4 behind it whats the best way to hook-up the the lock-up to the CPu on the motor or is it better not to put them together.
Thanks for the info.
VROD383 is offline   Reply With Quote
Old 12-25-2007, 04:52 PM   #2
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re: Putting in a vortec
I am doing the same conversion myself, so I'll share what I know. You have a couple of options. I have heard of some people getting a factory service manual and cutting their own harness. Another option is to send your harness and have them cut it for you. A place called Fuel Injection Specialties does this kind of work for about $450 if I recall right. The other option is to have a place a like Howell-EFI build you one from scratch for about $500. One thing to consider is what your local laws require for what emissions equipment that you will need to retain as part of the conversion. This will determine what programs need to be deleted from the cpu when it is reprogrammed as well as what parts of the harness need to be left on. Both places can do the cpu work for $250 to $350 depending on what you need. As far as the transmission is concerned, my understanding is that the cpu is only able to run the 4L60-E that was stock with those engines. You may also wish to contact a place called BTB Products, since they do these conversions as well, but their price tag is a little more then the others that I listed. Each place has a website and were very good about answering questions when I called them. If there are other things I can answer, feel free to ask. I'll help if I can.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 12-26-2007, 01:25 PM   #3
bdas70chevy
bdas70chevy's Avatar
i am doing the same set up from a 98 vortec in a 70 blazer. what i have found on the Tran 460le if it came from a 2wheel drive u need to get a tail shaft that advance adapters sells with a 205 conversion for the transfer case. summit has the same tailshaft as advance adapters for less money!! as for the wire harness i haven't decide whether or not to try to rewire or spend the money for someone else to But for sure u need to have the computer re-flashed. hope that helped
bdas70chevy is offline   Reply With Quote
Old 12-28-2007, 08:34 AM   #4
VROD383
VROD383's Avatar
what do you mean re-flashed what does that do for the computer?
Old 12-28-2007, 09:00 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You may also want to look into street and performance they have some pretty good info.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-28-2007, 05:54 PM   #6
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re-flash is just another way of saying to reprogram.
When I first started looking into doing this conversion, I called Street and Performance. My understanding is that most of their computer and harness work is farmed out to places like I mentioned do it for them and they mark it up.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
Sold.
THE STORY HERE
Old 12-30-2007, 05:41 PM   #7
bdas70chevy
can u find a wiring harness diagram on the internet? for that motor 98 vortec?
Old 12-30-2007, 05:56 PM   #8
1969k10stepside
Another thing,the 700R4 is longer than the stock tranny so if you have a 4wd you will need to locate the motor farther forward or move the t-case back resulting in needing new driveshafts or having the old ones lengthened/shortened.I'll just keep my good ol' carb'd small block chevy has used for decades and not have to do these mods,but that's just me.
1969k10stepside is offline   Reply With Quote
Old 12-31-2007, 05:35 AM   #9
VROD383
VROD383's Avatar
its go to be a 2wd now. thanks for all the info.
Old 12-31-2007, 05:58 AM   #10
bdas70chevy
cant u buy form AA the motor mounts and move the motor forward and leave the drive shafts alone. Use electric fans?
