12-30-2007, 03:23 PM | #1 |
layin frame?
Ok how low can you go? Can someone show me how low on stock trailing arms, Kp notch, and a lowering block, and bags(stock location or not)Will it lay frame on 20's? Someone show me their truck on this combo! What would it take to lay on trailing arms? Thanks Later
Tony from Norcal |
12-30-2007, 03:33 PM | #2 | |
Re: layin frame?
12-30-2007, 07:07 PM | #3 |
Re: layin frame?
Yes Prerunnerrob the rear trailing arms! I guess I should have made that part clear, sorry. I wanted to see pics of trucks bagged, blocked, Kp notched, modified or purchased trailing arm crossmember, on 20's to see if the are layin frame or how close to layin frame they are. Thanks for the help! Later
Tony from Norcal |
12-31-2007, 06:29 AM | #4 | |
Re: layin frame?
Here are some pictures. So, since i"m going to do this all again, I would weld in a notch, and 2 or 4 link it. Trying to save the stock trailing arms is more work then it is worth, and by the time I had finished placing the bags, I would have to box the lower arms anyway. Where are you located by the way? |
12-31-2007, 07:53 AM | #5 |
Re: layin frame?
Z-ing the rear frame 'clip' (from about the back of the cab) raises the frame rails to allow further drop w/o interference. You'll still need the c-notch/step-notch clearance. But if the rear clip is raised, you won't need as much of one.
It would prob be easier to just 4-link it. But. if you want the proven performance of the trailing arms & the rails to hit the dirt, it's going to take some work.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-31-2007 at 07:54 AM. |
12-31-2007, 08:37 AM | #6 |
A guy with a truck
Re: layin frame?
You will not even come close to laying with the bags in the stock location. I did this on my Blazer and with a step notch I am still about 3" from laying.
You can move the trailing arm perches towards the center at the axle. This will allow them to clear the frame. Keep in mind, this will also push the rear axle back a few inches so you will need to move the crossmember forward to re-center it in the wheelwells.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-31-2007, 10:32 AM | #7 |
Re: layin frame?
3" was the number I remember when I played around w/my 67 in the garage. This is why I figure a 3" or greater 'Z' behind the cab could theoretically allow the rails to sit on the ground & still utilize the GM supplied trailing arm configuration. Some aftermarket round=tube style arms might help w/additional clearance but the cost would off-set the benefit (aftermarket arms prob cost as much as a weld-in, basic style 4-bar kit).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-31-2007 at 10:33 AM. |
12-31-2007, 10:40 AM | #8 | |
A guy with a truck
Re: layin frame?
True, plus the fact you will need a custom length panhard or watts...
12-31-2007, 12:31 PM | #9 |
Re: layin frame?
All in all, in my opinion its just not worth doing all the extra effort to save the stock trailing arms. A conventional or triangulated 4 link will work better, allow alot more adjustment of pinion angle, axle centering, and operate smoother. You also dont have to deal with the pinion angle radicly changing throughout the travel arc. If you go with a triangulated, you don't even have to deal with a panhard bar. Just my 2 cents.
PS-my frame clip is getting cut off soon, if the person I told could have it falls through, it's up for grabs if anyone wants it. Last edited by PrerunnerRob; 12-31-2007 at 12:32 PM. |
12-31-2007, 12:55 PM | #10 | |
Re: layin frame?
Triangulated 4-bar, parrallel 4-bar, or trailing arm suspensions can all be made to work better than each other. Each has it's benefits; each can have negatives.
01-01-2008, 06:17 PM | #12 |
A guy with a truck
Re: layin frame?
There's pics in my "How to:" thread of the rear all the way down. The framerails are about 3" off the ground aired-out, but I am running a very tall tire(295/45-20). You could be as close as 2" with a 28" tire. You could easily put it on the ground by notching the rails for the arms or moving them in a little at the axle. I still have to trim the front fenders to put the front all the way down...
01-02-2008, 07:07 AM | #13 |
Re: layin frame?
Here are some pictures of the C10 that I did on 22's, with factory trailing arms, bags off the front of the axle, KP notch. You could go lower with a set of blocks between the axle tubes and trailing arms. This truck didn't have them because the truck was level when aired out and that's what the customer asked for. Plus the 22's were bottomed out up front on the hood hinge and the crossmember was on the pavement.
Good luck with your project.
- Clint - |
01-02-2008, 07:14 AM | #14 |
Re: layin frame?
If you were looking to go lower, then you could set the notch in a little higher and install the lowering blocks. DJM offers an adjustable lowering block kit which consists of (8) 1/2" thick plates and new U bolts. So you can lower each side anywhere from 1/2" - 2" inches.
You're going to need to relocate the shocks as well now the upper mount will be gone, and the angle off the trailing arms would be radical. The truck shown above uses our rear shock relocation kit and a new shortened pan hard bar with a 3 degree cope on the frame side, and a 3/4 heim joint on the axle side. Later.
- Clint - |
01-02-2008, 12:58 PM | #15 |
Seρor Member
Re: layin frame?
[QUOTE=Kontrol Phreaks;2509453]Plus the 22's were bottomed out up front on the hood hinge and the crossmember was on the pavement.
The math doesn't work for me... if you've got a 27" tire (ASSuming, based on the 22" wheel), and you're on the stock hinge up front, the xmember isn't on the ground. Am I missing something from your explanation of what was done??
01-03-2008, 04:39 PM | #16 |
Re: layin frame?
Up front I am running drop spindles with front airbag cup cut down to 1 inch. Out back a kp notch with a 2 inch block... I relocated my rear bags to the rear axle... With this set up the trailing arms touch the frame when dumped and the frame sits level.... with a 29" tire the bottom of the middle of the frame is 3 inches off the ground... It will drag the sh*t out of the rear license plate box but thats about it...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 01-03-2008 at 04:40 PM. |
05-07-2008, 11:43 AM | #17 |
New Member
Re: layin frame?
Well Tony hey when are you going to show us some pics?
Anthony 63 chevy stepside SWB 57 chevy 2dr hrdtop belair |
