![]() Join Date: Aug 2007
any 73-87 guys running 8" bags up front?
Like the title says, are there any guys with a 73-87 running 8" slam bags up front? I am running SD.com plates with ART upper and lower arms so if someone is running ART arms with these bags let me know if there is any rubbing or anything. I have a brand new set of 7" bags but I am thinking about running some 8's to be able to have a lower psi at the same height as a 7" bag.
Thanks for any help on this. |
Re: any 73-87 guys running 8" bags up front?
Sorry all the trucks I've ever done always had 7's in the front. I did use a set of 8's on a 73-87 dually with a big block, but it had factory control arms, and we had to trim the end of the sway bar a little for clearance.
I'm doing a large C30 box van right now with DJM lower arms and it uses a 7 to pick it up. Works out fine with the 3" drop spindles and the lower control arms.
I had 8's in the back of my 97 there just a little too soft, why would you want a lower psi at ride height? is it too stiff? if so change the position of your plates if you got room to move them and still lay out the bags are suppose to be in a certain position at ride height, there also might be some clearence issues to the spindle not sure never even tried to install up front, even dually's with diesels and big blocks lift fine with 7's
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
im runnin 8s on the frt of my 96 and at 60psi im at ride heigh and i can drive that high but at around 110 im maxed i the frt and im running no shocks at all.
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
#5 | |
But back to the original question not sure on the 73-87 since the 88-98 is a way different frame
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 01-06-2008 at 10:06 AM. |
#6 | |
the fab shack
#7 | |
![]() Last edited by red02chevy; 01-06-2008 at 01:32 PM. |
#8 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
the fab shack
yes and the 7's in the front.. you want a soft bag in the rear where there is no weight. a small bag (and a 7 isnt small, i'd personally run 7's all around, but a 6 is where you are too small) and the ride will be crappy as hell.
