Old 10-15-2002, 12:45 AM   #1
backinblack
Pinion angle question
Just got the c notch kit, and plan to flip my rear axle, on a 71 GMC SWB. This truck has had a shortened driveline for the 700 r4 in it. My question is: Will I need to shim the rear to correct any difference in pinion angle after lowering? Does it make a difference being a SWB?
What have you guys done?
Thanks in advance!!!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Hmmm. Too many pontiacs, not enough chevy trucks yet.
backinblack is offline   Reply With Quote
Old 10-15-2002, 08:48 AM   #2
crazy longhorn
Fabricate till you "puke"
Chances are that you will need to adjust the pinion angle. If you go to a Lowe's lumber store, you can pick up an inexpensive magnet base angle finder. You can check the pinion angle before & after, or check the trans ......if its 4 degrees down, set thhe pinion 4 degrees up. The trans tailshaft, & pinion just need to be parallell with each other. if you need to adjust, you should be able to get shims at a local spring shop. good luck ......AL
crazy longhorn is offline   Reply With Quote
Old 10-15-2002, 07:32 PM   #3
Mike C
Mike C's Avatar
Crazy Longhorn has got you setup. Also read here:
http://67-72chevytrucks.com/vboard/s...threadid=27249
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
