01-01-2008, 04:33 PM | #1 |
350 Chevy Short Block
This is a 350 I was building for my truck project. I'm going to go in a different direction with this project and would like to sell this engine. It's a 350 four bolt main block that was cleaned and bored .020 over. The stock rods were resized and fitted with aftermarket rod bolts and new Sealed Power hypereutetic pistons pressed on. The pistons have a small 1/8th inch dome that gives around 9.5-1 compression with open chamber heads and have new moly rings. The cast crank was turned .010 on the mains and .010 on the rods. The rod, main, and cam bearings are all new Clevites. There is a new Melling oil pump, pick up, pump shaft, and oil pan included all in there boxes. There is also a new Clevite brand camshaft with specs similar to a High Energy cam, a Cloyes timing set, and Sealed Power lifters. The unused but opened Felpro gasket set is also included. $1000, sorry can't ship this one.
01-02-2008, 04:01 AM | #2 |
Re: 350 Chevy Short Block
bump
01-03-2008, 03:33 AM | #3 |
another bump
01-03-2008, 10:13 AM | #4 |
Sophomore Member
do you need any parts as trade?
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
01-03-2008, 10:59 AM | #5 |
Maybe a pair of light weight wheels like Centerlines or welds in 15x10 size. Also a nice or repop 67 rt. front fender. big
01-03-2008, 02:57 PM | #6 |
Sophomore Member
don't have those. i have a very nice long bed, a nice 68 cab and doors, a short 71 frame, a nice core support, a nice short floor blasted and primed, but has a hole where a salt block sat and went through that would need patched, an nos short left bedside, an nos set of short 69-72 lower black mouldings, nice blue headliner and sunvisors, if any of this is something you could use let me know.
01-03-2008, 03:53 PM | #7 | |
There's no such thing as "open chamber" SBC heads - what cc head is required to give 9.5:1 (assuming 76cc?) Last edited by Billla; 01-03-2008 at 03:54 PM. |
01-03-2008, 05:43 PM | #8 |
Yes, 76cc heads. Meant to say low compression heads. I've got big blocks on the brain.
01-03-2008, 05:45 PM | #9 |
Sorry Highlander, don't see anything I'm in need of right now.
01-03-2008, 05:55 PM | #10 |
Sophomore Member
no biggie, mines original motor and runs great, i'm eventually gonna find one and pull original to build back stock for when my son is ready to drive it.
01-04-2008, 04:32 PM | #11 |
How about $900???
01-06-2008, 02:11 PM | #12 |
i like i like
