Old 01-02-2008, 08:12 AM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Inline 6 guys, EFI on my '72 250?
Was wondering if anyone here has put on some of the new EFI offerings for the 250's and 292's on their inline? I've been asking around and only really got good info from Larry@Clifford Preformance. Was curious as to the daily driveability of them. I am looking at a Howell EFI kit from Clifford to replace my 1404 500 CFM edelbrock with manual choke. The Carb on their intake works great, but since I use my truck often in the dead cold of winter a nice consistant idle without fussing with the choke would be really nice, along with a MPG gain, although I do really well with my carb I think. I need to make a decision soon as I have a leaky header on my 250 so I'll have it apart to fix that, and would bolt on the EFI then if I am going to do it.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 01-02-2008, 10:48 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Inline 6 guys, EFI on my '72 250?
I used the Howell kit on a 258 in a CJ-7 . It worked great .
hotrod 80 is offline   Reply With Quote
Old 01-02-2008, 01:44 PM   #3
BCOWANWHEELS
use the hot water from engine to heat your manifold.........
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 01-02-2008, 02:01 PM   #4
TP from Cntl PA
bob
Already have that in the form of a Clifford 4 brl intake...........Works well, but you still need the choke until the block warms the water enough to run without a bit of choke. I hope EFI would compensate for it and give me a good idle right from the moment I turn the key. This Howell Kit bolts on the clifford intake I already have.
Old 01-02-2008, 03:42 PM   #5
zeeklu
I have an electric choke on my 390cfm Holley and it works great on my 292.Mine idles great from cold start on. Could you put a electric choke on your carb? Chris
zeeklu is offline   Reply With Quote
Old 01-02-2008, 04:09 PM   #6
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Just drop 4.3 v6 into it. They are already fuel injected.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 01-04-2008, 05:17 AM   #7
Brad
Out of the carpool lane.
Brad's Avatar
TP, I've got the 1403 w/electric choke and after being adjusted correctly, mine idles great. I would think that your manual choke would be even easier to get to work correctly. Seems like you're stepping over a dollar to pick up a dime with the cost of a fuel injection setup.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-05-2008, 07:55 AM   #8
TP from Cntl PA
It does idle great once the intake manifold water heats up, until then it needs the choke out some. My problem is I drive from one farm up the road a mile to another farm, get out, get in, drive back down the road(25 mph tops) and it takes awhile for the 250 to warm up at that rate. So a consistant idle doesn't happen until the intake is warm without a bit of choke(Like today with a temp outside of ten)...........EFI would solve that problem I'd imagine. I guess what I am trying to say the issue here is I have other people running it as well in the cold, and some aren't as involved with playing with the choke a tad like I am, so to make it easier for everyone I'd like to change it. For $1200, I'd say with the fuel I'd save and the better driveablity immediately after startup would make it worth it I think.
Old 01-05-2008, 09:56 AM   #9
Basicfish
I have been thinking of the same thing. Many ideas with the MegaSquirt site. It is a DIY EFI system that you adapt to any auto. or if you have plenty of money buy one of the off the shelf ones.
Basicfish is offline   Reply With Quote
Old 01-05-2008, 10:07 AM   #10
shifty
Questionable
shifty's Avatar
Pretty much. When I saw the price tag of $3,500 for an EFI setup on my 250, that's when I finally said, "uh...earth to dummy" and went out to buy an '01 TransAm engine and 6spd tranny for my truck
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-05-2008, 12:34 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My nephew took an Olds 455, bored to 468, and then went on-line and found instructions to build an electronic fuel injection system. Used Ford injectors and built the box to control the system. The whole thing is in a '79Trans Am, originally equipped with an Olds 403. Runs a lot better, he says.
Member Nr. 2770
Old 01-05-2008, 12:47 PM   #12
68gmsee
Active Member
68gmsee's Avatar
My 68 inline six is also a pain with the manual choke when it's cold. I have to sit there for about 5 minutes or so to warm before I drive it. The good thing is it doesn't get very cold down here.
I have been considering an electric choke for future use, though. I just can't see paying the money for an efi.
68gmsee is offline   Reply With Quote
Old 01-05-2008, 03:04 PM   #13
TP from Cntl PA
This EFI is $1200 for the works. I seen a parts list of everything I'd need to put such a setup together with off the shelf parts............But that would end up being $800 plus my time, so I don't see where the bolt on kit and go at that price is all that bad............IF it works as well as they say.
On days like today when it was 10 degrees it really gets annoying playing with the choke. I had a small block with electric choke that worked well, but even the book says it needed adjusted periodically throughout the year with temperature changes(This was a 600 CFM edelbrock)..........For me, that is just an annoyance to do every so often. I want something that is done once and is done for a good while. I just hate to be the curious george and try the kit myself, I figured maybe someone else out there already had one on a truck for a time now.
Old 01-04-2008, 08:26 AM   #14
Ackattack
Ackattack's Avatar
I added an electric choke to the edelbrock carb I had on my old 327. It was an easy install, and worked good. Check into that.
Ackattack is offline   Reply With Quote
Old 01-04-2008, 11:32 AM   #15
tkeduk8r
tkeduk8r's Avatar
Ive had half an idea to try a chrysler TBI set up of a 4.0 jeep on a 250 or 292... Tons in the jyard and most will give them away... but then again maybe im nuts (i do enjoy machining)...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
