01-03-2008, 05:22 PM | #1 |
Robert Olson Transport
motor mounts
the other night i was backing my truck into a spot and the truck seemed to slam into reverse, and when i would goose it to get it to move the whole motor seemed to be slamming around, so anyway today my buddy came over and he had not seen the truck before so i took him out there to see it and we were looking it over and i decided to check the motor mounts.. Ive never seen motormounts in such bad shape.. they were almost completely gone.. the rubber inside i mean
guess its time for a new set.. Is one brand better than the others? or should i just get the ones from the auto parts they offer for cheapies? At some point ill prolly post pics of them
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-03-2008, 05:30 PM | #2 |
Re: motor mounts
I never had a problem from the ones at the auto parts store. they cost me like $15 for the pair. That's what I always get. Good luck!
01-03-2008, 05:58 PM | #3 |
Re: motor mounts
i looked briefly on an online store and they say the standard type is $8.98 each and they have energy absorbing ones for like $26.99 each. i guess those are polyurethane? theres no advantage to them?
Im gonna go as cheap as i can i guess the cheapies are the same as the OEM type? I know all the mounts for small blocks are the same so there is no problem when i upgrade to a 350
01-03-2008, 06:06 PM | #4 |
Garage Queen Material
Re: motor mounts
the front mount on my '01 passat is bad. i need to replace it asap but keep putting it off.
for a stock application, the rubber ones will work just fine. i've got poly mounts in my truck though. |
01-04-2008, 04:13 AM | #5 |
Re: motor mounts
They're probably polyurethane. Polyurethane is a lot stiffer than rubber, usually used in performance applications. I had a set in an old mustang I had, and mostly what I noticed is it transfers more vibration to the frame, and to you. Its a step between rubber mounts, and solid metal mounts used in racing. So after that I went back to the stockers and liked them much better. Usually on a daily driver the only thing I like polyurethane on is a sway bar. Good luck!
