Old 01-04-2008, 11:33 AM   #1
69gmc292
heater core position
i changed out the heater core on my 69 gmc C1500 and was wandering which way the heater inlets went my truck never came with a core and i think the 3/4 inlet is on the top thank you
69gmc292 is offline   Reply With Quote
Old 01-04-2008, 01:27 PM   #2
john
member #16
john's Avatar
Re: heater core position
I think you are right.
john is offline   Reply With Quote
Old 01-04-2008, 03:06 PM   #3
72ChevyAZ
LWB Club
72ChevyAZ's Avatar
How was that whole job (installing a heater core)? I just found out today that mine is leaking. Never tackled this but gonna give it a try. Anyways, here's a bump for ya.
72 Chevy Custom LWB
72ChevyAZ is offline   Reply With Quote
Old 01-04-2008, 06:47 PM   #4
69TowRig
It is not bad, hang the hood from something above (or take the hood off), remove the passenger side hood hinge. Disconnect and remove the fan, then all the screws, carefully pull the box away from the firewall and disconnect the heater flap from the control cable. I did that over a year ago, I think you might have to undo something inside the cab too. It is pretty obvious when you are in the midst of it.
I'm in agreement (3/4" on top).
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 01-05-2008, 02:47 AM   #5
70GMCer
70GMCer's Avatar
Just did mine back in Oct. I didn't have to remove the hood hinge though. Just drop the inner fender down.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-05-2008, 02:57 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
in the 5/8 and out the 3/4. otherwise you will create higher pressure in the core leading to eventual blow-out. that is the way the engineers made them.
if you see a car with the same size on both then the feed has a restrictor inside.
68C15 is offline   Reply With Quote
