Old 10-15-2002, 06:12 PM   #1
darrel_s
darrel_s's Avatar
Unhappy New Radiator. No HRL?
This may be a stupid question, but I'd rather ask then go through another mail order return for nothing. Just got my new radiator in. Problem is it doesn't have the Heater Return Line outlet for the heater hose.
Am I correct in thinking I can just run the hose that use to go from heater coil to radiator into my extra outlet on water pump? Would this be an acceptable alternative flow direction for this hose, or should I return the radiator and get one with a HRL? Thanks
darrel_s is offline   Reply With Quote
Old 10-15-2002, 06:32 PM   #2
vcrazy8
That is the way I ran my return. Works good
vcrazy8 is offline   Reply With Quote
Old 10-15-2002, 07:29 PM   #3
Desert Rat
Desert Rat's Avatar
Ive never seen a stock radiator on 67-72s with a heater hose to radiator,but the 73 ups do,put in water pump,and should be a fitting on intake.
Desert Rat is offline   Reply With Quote
Old 10-15-2002, 07:33 PM   #4
Mike C
Mike C's Avatar
Desert Rat is on. Sounds like somebody had swapped a boneyard rad into your truck. Put the "in" hose to the water pump and the "out" hose to the intake.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-15-2002, 07:54 PM   #5
darrel_s
darrel_s's Avatar
My original water pump does have a plug in it, but I wasn't 100% sure that was the way to go. Thanks for the posts.
Old 10-15-2002, 08:13 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
All of my trucks with automatics have the 3/4" heater hose connecting to the radiator. You will be just fine by adding the correct fitting to your water pump. The one just above the radiator hose inlet is the normal connection point then, not the one straight out the top of the water pump.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 10-15-2002, 08:36 PM   #7
slam33
slam33's Avatar
The correct rad has the 3/4 hose that clamps to it. I doubt that you will find an aftermarket rad that set up that way.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
