Old 01-06-2008, 07:25 PM   #1
r8edx2000
6L80E swap
Has any one thought about putting a 6l80e behind a gen III motor swap. It sounds kind of cool to have 6 gears. I thought of puting a lq9 and a 6l80e into my 67 c10.
r8edx2000 is offline   Reply With Quote
Old 01-06-2008, 07:27 PM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 6L80E swap
Not happening without a LOT of work. The 6L80E uses a separate TCM from the ECM of the GenIII engines, and they use a different communication protocol, so they will not talk to one another.
Also, to my knowledge, at this time there are no stand alone 6 speed controllers available at this time.
I'd be all over it, otherwise!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-06-2008, 07:46 PM   #3
68 short step
Re: 6L80E swap
i beleive a E38 PCM and the TCM for that trans will work just fine...im currently talking to a customer of mine about this trans....its not a huge pain, like mentioned, but will require some computer and tuning knowledge...also john at speartech, makes a harness for just this, i think its 750$ well worth the $ if you dont wanna fool with anything..
68 short step is offline   Reply With Quote
Old 01-07-2008, 10:40 AM   #4
Wasted Income
Boosted Member
Re: 6L80E swap
The E40 was used on LS2 motors with the 24X reluctor, vs. the E38 LS2 engines with the 58X reluctor.
You'd need to either use an E40 set up for 24X or swap reluctor wheels on the LQ9.
Turbo diesel
Old 01-07-2008, 12:55 PM   #5
jrb71c20
jrb71c20's Avatar
Re: 6L80E swap
Orrrrr, you could get some more 710 for your flux capasitor and simply bypass the hooter with a dial barometer...Sheesh, you guys shoulda asked me sooner...
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
Old 01-07-2008, 01:01 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 6L80E swap
Just yank the whole drivetrain out of a wrecked 07+ 6.2L denali or caddy. 400HP and 6 gears
If GM would ever get off their ass and offer the 6 speed on the 4.8 and 5.3L 1/2 ton trucks and SUV's, it would be a lot easier. It was supposed to be on the '08's but it's been pushed back to '09.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-07-2008, 01:49 PM   #7
68 short step
Re: 6L80E swap
only a fellow okie from claremore, can make it so simple for us...
Old 01-07-2008, 02:28 PM   #8
jrb71c20
jrb71c20's Avatar
Re: 6L80E swap
Originally Posted by 68 short step View Post
only a fellow okie from claremore, work make it so simple for us...
Amen, brother!!!
93 Sonoma 2.8/5spd
Old 01-07-2008, 03:47 PM   #9
Rokcrln
Rokcrln's Avatar
Re: 6L80E swap
Speartech LS2/6L80E swap!
That was a good read! Speartech even states that a 69 C10 would be the perfect platform for this swap!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-07-2008, 04:22 PM   #10
68 short step
Re: 6L80E swap
Kevin
LFD Inc.
stay tuned and you may see it in a 71 truck im doin
Old 01-07-2008, 01:53 PM   #11
HarrolLS1
HarrolLS1's Avatar
Re: 6L80E swap
http://www.performancetrucks.net/for...d.php?t=401899
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline   Reply With Quote
Old 01-09-2008, 08:24 AM   #12
Wasted Income
Boosted Member
Re: 6L80E swap
Originally Posted by HarrolLS1 View Post
Great find. Thanks!
Turbo diesel
Old 01-08-2008, 12:29 AM   #13
smbrouss70
smbrouss70's Avatar
Re: 6L80E swap
Anybody know what the gear ratios are on the 6 forward gears?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is online now   Reply With Quote
Old 01-08-2008, 09:49 AM   #14
HarrolLS1
HarrolLS1's Avatar
Re: 6L80E swap
6L80E
Type: Six-speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
Maximum engine power: 413 bhp (308 kW)
Maximum engine torque: 430 lb-ft (583 Nm)
Maximum gearbox torque: 664 lb-ft (900 Nm)
Gear ratios:
MYC
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: -3.06
Maximum shift speed 6500 rpm
Maximum validated weightstarget ) GVW: 8600 lb (3901 kg), GCVW: 14000 lb (6350 kg)
Case description: Three-piece ( Bell, main, extension)
Case material: die cast aluminum
Shift pattern: (2) Three-way on / off solenoids
Shift quality: Five variable bleed solenoids
Torque converter clutch: Variable Bleed Solenoid ECCC
Converter size: 300 mm ( reference )
Fluid type: DEXRONŽ VI
Fluid capacity: w/ 258 & 300mm converter 258 mm: 9.7 L (8.22 kg), 300 mm: 11.9 L (10.1 kg)
Transmission weight: w/ 258 & 300mm converter 258 mm: Wet: 94-96 kg (207-211 lb)
300 mm: Wet: 102-104 kg (225-229 lb)
Pressure taps available: line pressure
Assembly site: GMPT Ypsilanti, Mich.
Applications:
Chevrolet Corvette
Cadillac XLR
Cadillac XLR-V
Cadillac STS-V
GMC Yukon Denali
GMC Yukon Denali XL
Cadillac Escalade
Cadillac Escalade ESV
Cadillac Escalade EXT
http://wheeltalk.fancal.net/?p=358
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Old 01-08-2008, 10:21 AM   #15
smbrouss70
smbrouss70's Avatar
Re: 6L80E swap
Thanks!
Man, that's a steep first gear! You could run a 2.73 rear gear and still launch harder than a 4.11 with a TH400! And with 6th gear still have a similar ratio as a T-56 with a 3.73!
But with such a wide spread between first and second gear it would be worse than a 700-r4. You would launch, then bog unless the engine hooked up to it has a W-I-D-E torque curve.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 01-09-2008, 04:08 AM   #16
67ChevyRedneck
Re: 6L80E swap
Originally Posted by smbrouss70 View Post
Thanks!
Yes, it is. So steep, that GM doesn't offer a rear gear any higher than a 3.42 on the new Sierra Denali's and it can still beat/compete with (magazines all come up with different track #'s) the 4.30 rear geared Tundra's.
A Sierra Denali would be a neck snapping rocket with a 4.10.
Jesse James
Project "On a Dime"
Old 01-08-2008, 06:22 PM   #17
panteratron
panteratron's Avatar
Re: 6L80E swap
Thats the set-up I would like to have, all stock for a daily driver. Whenever someone gets this installed in a 67-72 I would like to know what all you have to get and where to get it.
panteratron is offline   Reply With Quote
