01-08-2008, 04:11 AM | #1 |
90 vs 91 ECm's
For the 3/4 ton Suburban, was it the first year for the 4l80e?
If so, would it be feasible to buy a 91 ecm with trans harness and install the 4l80e in a pre91 equipped with TBI? TIA- John |
01-10-2008, 04:06 PM | #2 |
Re: 90 vs 91 ECm's
I believe that 93' or 94' was the first year of the 4L80. never available in the old style truck as far as I know, I would buy a stand alone controler, available at summit ETC They had throttle bodys up to and including 95' but I don't know if a ECM from a newer style would work?
01-11-2008, 11:45 AM | #3 |
Re: 90 vs 91 ECm's
cartman- thanks...I saw a 91 for sale and it said OD.
The truck appeared to be all original so I thought that if it was the first year it would be an easy swap |
01-11-2008, 01:12 PM | #4 |
Re: 90 vs 91 ECm's
Probably has a 700r4, that would be "od"
01-11-2008, 01:59 PM | #5 |
Re: 90 vs 91 ECm's
Probably swapped....thanks-
john |
01-17-2008, 12:15 PM | #6 |
www.73-87chevytrucks.com
Re: 90 vs 91 ECm's
1991 was the only year for the 4L80E our bodystyle, it was only available on the 1Tons as far as I know, but it could have been on 3/4T. The ECM has the controls for the 4L80E built in, so yes could use it in a 87-90 with TBI if you have the harness....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-17-2008, 03:26 PM | #7 |
Re: 90 vs 91 ECm's
Appreciate the info...I am watching a few on ebay...there is a 90 locally that needs a trans. (t400 is gone...sounds like front pump).
John |
01-27-2008, 10:36 AM | #8 |
Re: 90 vs 91 ECm's
Does anybody have the ECM number for the 1991, 454, 2wd with 4l80e?
Thanks- john Last edited by ponjohn; 01-27-2008 at 10:37 AM. |
02-13-2008, 07:21 AM | #9 |
Re: 90 vs 91 ECm's
1991 was the first year to use the 4L80e. It was used I knmow for sure in the 3/4 Suburbans and the 1 ton trucks. I have parted out 3 of the burbs and they were all 3/4 ton and all had the 4L80e trnas, 2 were small block and 1 big block 2 wheel drive. I will see if I can find the right computer from the big block. I know I have all the wiring from the small block that had the 4L80E, not sure what the difference was betwen them.
02-13-2008, 10:01 AM | #10 | |
Re: 90 vs 91 ECm's
The 7060 is now superceded by 88999179, if buying from GM. The schematic shows gas w/4l80 and gas w/o 4l80. The prom prob has a diff prgram for the larger cubic inch. I would say same ecm. Last edited by ponjohn; 02-13-2008 at 10:05 AM. |
02-13-2008, 01:20 PM | #11 |
Re: 90 vs 91 ECm's
I took out the entire harness from the 91 Burb, do you need all the harness for thew swap or just the engine and trans computer wiring for the ECM?
02-13-2008, 08:28 PM | #12 |
Re: 90 vs 91 ECm's
02-13-2008, 08:47 AM | #13 |
Re: 90 vs 91 ECm's
The ECM on the 4L80E is 16147060, same as what was on the 1993 454SS.
02-13-2008, 09:05 AM | #14 |
Re: 90 vs 91 ECm's
IS the ECM the same on the big block and the small block with the 4L80E?
02-14-2008, 02:29 AM | #15 | |
Re: 90 vs 91 ECm's
You want the DRAC = (Digital Ration Adapter Controller) it should be located under the dash below the radio (little white box). It usually is just clipped there If you already have one you just need to recalibrate it, or you could ditch it and use a VSS. Found the link for calibrating...http://www.614streets.com/drac.html
03-24-2008, 06:49 AM | #16 |
Re: 90 vs 91 ECm's
Sorry to revive this, but I just bought a 1/2 ton 91 burb SLE and it has the 4L80E. It also has about almost every other option on it so maybe that trans was a special order for the 1/2 ton???
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi |
