![]() Join Date: Apr 2007
Blazer windshield frame help!
Here is a pic of my windshield frame corners currently - Anyone got a pic of what they should look like??
Its lookin' like a Blazer!
Re: Blazer windshield frame help!
Too late to take any pics tonight. But I saw this awhile ago.
It may help. http://67-72chevytrucks.com/vboard/s...ghlight=Blazer |
Here's a couple of pics of my replacement that has yet to go in. Excuse the junk around it, it's presently in the computer room closet (safe from rust.)
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
SKINNY TIRES RULE!
Looks like youv'e got the metal inside the rubber seal still stuck there.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Thanks - these are helpful...
Here is the other side. |
SKINNY TIRES RULE!
Nice Nova!
The windshield frame doesn't look too bad,
The LuvShack Garage
Yeppers, have seen ALOT worse
belly dragger
Looks better than mine did.
SAVE THE PLANET DRIVE AN OLD TRUCK |
My paint/body guy has done several of the trucks but no Blazers, so i want to provide him with some good pics of what it should look like behind the rubber.
Do you need better, bigger pics?
Ok, here are some better pics. The 2 inside holes on each side have a nut welded on the backside, and the outside hole on each side takes a "slip-on" nut thingy (don't know what to call that.) My measurements in the last pic are as close as I could get them with my eye and a tape measure, but should be close enough, maybe with the new weatherstripping in hand you can get a better fit. These are loaded onto my photobucket account, and it resizes them a little. If you want the fullsize pics, PM me your e-mail address and I wil send them to you.
If you need any more pics at different angles or anything, let me know and I'll get them for you. Driver's Side ![]() Passenger's Side ![]() Passenger's side with measurements All measurements are to the center of the threaded portion (to the best of my ability right now.) The purple measurement is to the little corner, which shows up better in the driver's side pic. ![]()
Those are great - thanks for taking the time to help.
#15 |
No problem, I know anybody on here would help me, so the least I can do is help where I can.
#16 |
![]() Join Date: Feb 2000
So when I take off the plate that is pictured in post #1, will my frame look like what is shown in smbrouss70's reply?
I guess what I'm asking, smbrouss70, did you weld in new nuts and add the caged slip on nut or is that factory?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#17 |
I assume that's how it came from the factory. At least that's how it came from Frank (PICKMUP)
#18 |
SKINNY TIRES RULE!
The plate is actually embedded in the rubber door seal. It looks to me like the pic in #1 is the plate with all the rubber rotted away.
#19 |
That is awesome news as I have new door rubber seals that I haven't installed yet - I was assuming I was going to have to do my best at making that metal piece. Never guessed it was part of the door seal!
#20 |
Could this part of the windshield frame be solid or does it have to have the opening??
#21 |
SKINNY TIRES RULE!
They had openings from the factory, but I don't see why you couldn't make it solid as long as you get all the moisture out of it.
#22 |
