R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Stock Steering wheel part question
I'm putting back my stock wheel and have all the parts except the spring that goes behind the horn contact. (its the one under #14 in the pic)
Does anyone know where to get one besides just going to Pic A Part it doesn't look like it's repoped......Chevy Dealer???? Thanks Paul. ![]()
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
Active Member
![]() Join Date: Jul 2007
Re: Stock Steering wheel part question
Not sure which one you mean...
Under 14 is 13??? |
R.I.P. E.S.L.L.
its the little spring kinda under to the right of the 14 its greyed out in the pic.
Active Member
10/4. I see it now.
Check the www.classicparts.com site on page 40 of the catalog. (32-493B). It's the aftermarket kit but I think it has what you need. About the only other thing you may be able to do is to see if you can find one in a junkyard as you mentioned. Last edited by 68gmsee; 01-10-2008 at 06:05 PM. |
Active Member
Additional info.
I was looking at the actual catalog but the site shows this one that you may be able to use??? http://www.classicparts.com/prodinfo.asp?number=32-493C |
#6 | |
huh ???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched Last edited by DavesRide; 01-11-2008 at 02:29 AM. Reason: bad eyes |
R.I.P. E.S.L.L.
Thanks for the replies, I may have to hit the junkyard I hate to buy a kit when all
I need is a little spring.
member #16
![]() Join Date: Dec 1999
This may sound funny, but I have used a shortened spring out of a ball point pen.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
R.I.P. E.S.L.L.
youre thinking of the little spring on the contact, yeah it looks like a pen spring, I've got that one, the one I need is the one that goes around the center shaft it's probably about 3/4 inches wide and a inch tall.
If it,s a non-tilt column it doesn,t use a spring there. The spring is below the lower brg. #44. When you tighten down the strg. wheel nut it pulls up on the shaft & compresses the spring.
member #16
Paul if you have a tilt column the cancelling cam will look like the one on them left with a spring under it. A standard column has a cancelling cam like the one on the right, and it is as wrenchbender ret describes. If you need one for tilt you should be able to find at a hardware store.
R.I.P. E.S.L.L.
OK mines not a tilt, and I've got one one the taller white cams so I'm good to go..Thanks..
