![]() Join Date: Aug 2006
FS: Custom tube frame with a dropmember and air ride
Well i am finally selling my other frame. I need the money to finish my current frame and project. I was building this frame before i went out of town a little less than 1 year ago for work and after i got back i found a c5 drivetrain that i decided to put into my truck so i no longer needed this setup. I wanted to keep it but things have changed a little. Here is a run down on what is installed in the frame. Please email for any questions.
Custom built tube steel frame Porterbuilt dropmember with power rack and pinion Brand new cross drilled and sloted rotors with new calipers front and rear Air ride technologies strong arms Air ride technologies shockwaves for the front and rear 12 bolt rear end (not posi) Air ride technologies trianglated four link Cantilever rear suspension which gives you about 9-10" of lift Rotors have been redrilled to 5x4.75 bolt pattern for a wider wheels selection and more.... The frame was designed to have a 7" ride height. The dump height is right about 2-2 1/4" off the ground to the rockers. I designed it so if an airbag ever popped i wont drag the frame or rockers. I am only trying to get the money i have in the frame out so basically you are getting a custom frame for free! Please email me for any quesitons. PRICE is $7250 for a complete rollin chassis minus the wheels and tires The wheels and tires in the pics do not come with the frame.
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: FS: Custom tube frame with a dropmember and air ride
Here is a few pics showing the dump height and the frame with some sheetmetal
Also one more thing. The frame has stock spindels. If you put drop spindels it will lay rocker.
SKINNY TIRES RULE!
Wow, heck of a deal. Looks like great craftsmanship. I assume it is a shortbed pu frame? It would almost be a shame to put a body on it and cover it.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
wow this post pisses me off... i honestly would have made the 3000 mi + trip to pick this up if you only listed it a month ago.. GREAT DEAL!!!
#5 | |
![]() Josh
sounds very tempting.. (the trip that is) never been to cal. wife wants to check it out also.. hah i had bought one for 6k and it didn't have all that yours had.. my stomach is STILL turning!! ohh well, your new project is KILLER!! keep the pics comin
ohh yea 1 thing josh.. im assuming by watching the frambe build that you ordered your wheels before you had it all together.. how did you know the correct backspacing for the wheels.. (nothing i hate more than nice rims tucked into the fender 2" too far on each side) and also, when you get a chance what is the width of your rear axle.. i think mine is narrowed.. but not 100%
#8 | |
Josh
ttt
Insert Title Here
cant believe nobodys jumped on this... maybe you should try $7000 with the wheels...lol
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#11 | |
New price is $6850. I am also willing to build a new frame using all of the components from my frame like shockwaves, dropmember, strong arms and so on. The reason i am willing to do that. There were a few areas that i could have done different. For example. The rear rails sit about 1-1.5" above the rear end so if I lowered it by an 1" or so that is that much more bed space you get. That kind of things. Plus you get a frame a little more personalized to you specs. That way you get a perfect setup for your needs.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold Last edited by abadsvt; 02-10-2008 at 11:59 AM. |
Is the drop memeber the bolt in version of the c-10 that you welded in place or does porter have them in weld in versions?
#14 | |
Josh
