Old 01-11-2008, 01:16 PM   #1
TonyJohnson
TonyJohnson's Avatar
Fixing Drip Rail on Top
Anyone have any ideas or sources to repair the drip rail that goes around the back of the Blazer/Jimmy top? A section of mine broke in the upper right corner above the hatch glass and I'm wondering what I should use to try and repair it. It looks like a piece could be molded and cast if the material was somewhat flexible? Any idea? I'm certainly not a fiberglass guy, but I'd like to try to redo my top this spring when it's off the truck.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 01-11-2008, 03:57 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Fixing Drip Rail on Top
French Blue was throwing out 2 tops, see if you could get him to cut out a section, then you could just resin it on yours....J
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-11-2008, 07:42 PM   #3
TonyJohnson
Great idea. Thanks!
Tony Johnson
Old 01-12-2008, 05:30 AM   #4
fun in dirt
fun in dirt's Avatar
I re-did mine a few months ago & it turned out great:
1.)Took a piece of small brazing rod & bent it to match the shape along the edge.
2.)Used some masking tape to hold it in place
3.) Mixed up a little kitty hair (green bondo like stuff with fiberglass strands in it) and applied - but not over tape.
4.) When that dried, removed tape & fill in those spots too.
5.) Sand down to desired shape and waalaa a new drip rail!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 01-12-2008, 05:54 AM   #5
TonyJohnson
That sounds pretty good. I hadn't heard of the kitty hair. That will be handy for the rest of the top repairs. Thanks!
Tony Johnson
Old 01-12-2008, 12:47 PM   #6
fun in dirt
It's not good for structural type areas, but great for everything else & filling in odd spots. Can get it anywhere like Auto Zone or such. In same type can as bondo but will say something like "with fiberglass strands".
'85 K30 "Big Nassy"
'06 C1500 WT...DD
