As I have a 3/4 ton '71 GMC and want the looks of a 1/2 ton GMC, can I just change front spindles and coils plus the rear end? I want to lower the truck 4" and use 5 lug wheels all around. The darn truck is just too high.
Truck'n the alcan
Welcome aboard. Try using the search. I'm sure you'll find lots of info.
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van |
Fabricate till you "puke"
On the front end, you will need to use the 1/2 ton lower a arms, all 4 ball joints, & the outer tie rod ends, then the spindles will bolt on. Are you leaf or coil on the rear?
