Old 01-13-2008, 01:13 PM   #1
Select
Friday's Toy
Select's Avatar
Turbo 400 rattles?
What would make a turbo 400 rattle at a stop light, but fine going down the road, fine in park and neutral? It doesn't really bother me because you can't hear it outside cause of the exhaust but I was wondering if I need to take care of this before it becomes a bigger problem. Thanks in advance, Michael.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 01-13-2008, 01:15 PM   #2
skokie
skokie's Avatar
Re: Turbo 400 rattles?
Have you checked the flywheel cover to make sure it is secure? I ask this because I had the same problem and mine was loose.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-13-2008, 02:03 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Long time ago my brother had a noisy transmission. He found the flex plate/flywheel was cracked.
Check all the mounting bolts for any of them being loose or for any cracks.
68gmsee is offline   Reply With Quote
Old 01-13-2008, 07:58 PM   #4
tsetsaf
Have it checked out. If your tranny goes you are stuck.
tsetsaf is offline   Reply With Quote
Old 01-13-2008, 08:19 PM   #5
Select
Friday's Toy
Select's Avatar
thats what makes me worried ... being stranded.
2009 Jeep Rubicon
Old 01-13-2008, 08:22 PM   #6
Select
Friday's Toy
Select's Avatar
my pipes are very close to my crossmember
2009 Jeep Rubicon
Old 01-13-2008, 08:18 PM   #7
Cannon007
if it was the flywheel it would make the noise in park or N, only making the noise in drive says to me something to do with it vibrating. maybe the exhaust or something near the tranny vibrating on it that sounds like its coming from it?
Cannon007 is offline   Reply With Quote
Old 01-14-2008, 05:09 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Not necessarily. Remember that a slight amout of torque is applied when stopped in gear (less road and exhaust noise makes it more noticeable), more torque as you apply power (pressure on loose bolts could diminish play), and no torque when in neutral or park.
Select, aside from that possibility, what engine do you have. Mine has a rattle when in idle coming from the heat riser on my 6 cylinder. But any loose metal can cause, this especially in idle if the engine has a rough idle. Most engines smooth out at higher speeds.
