01-18-2008, 06:40 AM | #1 |
Brake booster
I have added disk brakes to my 67. How well will It stop without the booster?
01-18-2008, 06:53 AM | #2 |
its all about the +6 inches
Re: Brake booster
it'll stop fine, you'll just need to press harder.
01-18-2008, 07:00 AM | #3 |
Re: Brake booster
Better than drum?
01-18-2008, 07:58 AM | #4 |
Old Skool Club
Re: Brake booster
It should, but there's a lot riding on the "IF's"....
The vacuum booster just increases the force applied to the master cylinder. If you are young and strong of leg, you should be able to lock the brakes and scare the crap out of everyone else on the road with you!!
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-18-2008, 09:22 AM | #5 |
Active Member
Re: Brake booster
Supposedly, you will have to depress the pedal harder with disc brakes. You have less surface area, but the main reason is that drums brake shoes actually expand against the drum when stopping. The best explanation I've found, is in "How stuff Works." Believe it or not, they have a good example of how they operate.
I don't believe I've ever seen a front disc brake vehicle without power... http://auto.howstuffworks.com/drum-brake1.htm Last edited by 68gmsee; 01-18-2008 at 09:28 AM. |
01-18-2008, 09:33 AM | #6 |
Crew Cut
Re: Brake booster
if you seen mike nutts build he has this set up. it stops just fine , but you do have to make up for the booster with your leg.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
01-18-2008, 09:36 AM | #7 | |
Java Mechanic
Re: Brake booster
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
01-18-2008, 11:42 PM | #8 | |
Active Member
Re: Brake booster
I've replaced a lot of brake shoes and pads on vehicles, but I've never worked on or driven a disk brake vehicle without power. So, I really have no personal knowledge of how much more pressure you would use on one versus the other... |
01-18-2008, 09:39 AM | #9 | |
Son of a gun
Re: Brake booster
Bill BEATERS ARE NEATER |
01-18-2008, 07:58 AM | #10 |
I am a Referee of life.
Re: Brake booster
There's no clear answer to your question.Manual discs should work fine.So should manual drums.That is if they are in good shape.Actually drums should have more friction surface and theoretically should be better at stopping your truck but the discs radiate heat away faster and the heat is what causes brake fade.I'm in the process of converting to power discs,mostly because I want a lower stance and I do a lot of driving in heavy traffic.The reduced fade should be good for that.Serviceability is also enhanced by discs.You probably wont see much difference in pedal pressure but you will have better repetetive braking.Hope this helps you.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-18-2008, 12:47 PM | #11 |
Broken Down
Re: Brake booster
No matter what brake style you have " Brakes are only as good, as they can disapate the heat they generate"
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” Last edited by kenm78; 01-18-2008 at 12:48 PM. |
01-18-2008, 01:29 PM | #12 |
Re: Brake booster
there were millions of cars ahnd trucks made with disks and no booster.
01-19-2008, 09:23 PM | #13 |
Re: Brake booster
mine has no booster and it is disc/drum and it stops fine . hell it stop better then alot of new cars i drive at work
01-20-2008, 12:58 AM | #14 |
Junior Member
Re: Brake booster
My '71 C-10 came with manual disc brakes. I like the way they feel, but they do take more force to operate.
I can lock them up if I want without any problem, but I like the control manual brakes gives me. My son put power disc brakes on his '70 C-10 short bed and he likes them but they feel a little touchy to me. Danny-Southeast Missouri |
01-20-2008, 01:59 AM | #15 |
Old Skool Club
Re: Brake booster
Praise Brake Dyno (website??) has/had kevlar brake linings that they said would put a lot of other braking materials to shame. Saw an article in a magazine about them and they were quite complimentary. Drum brakes that stopped better than any 4-wheel power discs, they said.
