84 with a Dropmember
Here's a couple pics of an 84 we're installing a Dropmember in... also will be running a bolt-in rear kit that we will be offering soon (has the bolt-in notch installed already).
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Re: 84 with a Dropmember
Looks good, tha stance looks great..
Chickenhouse chopshop 81 rcsb chevy bagged LS1/4l60E(under the knife) 94 ecswb L92 headed LQ9/ 4l80E(waiting to go under the knife) 78 rcsb chevy LQ4/4L80E |
Awesome..
Wishin' I had more money!
Man I gotta stop by your shop sometime! Every post I see from you has some sick pictures in it!
Where you guys at? |
67-72 parts collector,…
![]() Join Date: Nov 2002
Subscribing to this one!
yeller
That looks nice!
Question, what does your basic 73-87 front kit go for? Any idea on what the rear kit might go for?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#7 | |
Happy to be here
![]() Join Date: Mar 2000
#8 | |
yeller
I don't think so on Yeller...but perhaps something else? Ken, can you use these kits stand alone (no drop spindles/springs/air bags), and if so, what is the drop? I am thinking of doing this in stages...IF I do something like this. I know you don't make these, but you might know about them.
#9 | |
#10 | |
On the rear... still finishing it up. Hopefully I will have it completed by the first of next month and be able to attach a price to it.
Happy to be here
Nathan thanks for dropping in on the 73-87 forum. For those of you that don't visit the suspension forum, Nathan Porter (Poreterbuilt) is a regular there. If you spend some time looking at his posts you will see some amazing quality work.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-19-2008 at 12:33 AM. |
Happy to be here
Jeff, I don't know much about the rear kit since it is new. The front kit is designed to get you on the ground. I think you can use the stock spindles, but bags are part of the package.
I'm sure Nathan will drop in with more details.
i love those wheels.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
yeller
Thanks for the info, nice work BTW.
#15 |
Tot Roddin'
Sahweeeet!!!!!!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
#17 |
Happy to be here
#18 |
Here's a few more pics of the rear nocth and install (kkep in mind these pics do not include all pieces of the rear kit). There will also be tubular crossmember's that bolt-in between the notches to stiffen the chassis and add a little flavor!
This shows the simplicity of the design... use the supplied templates and existing frame holes to mark where the frame needs to be cut and where the new holes need to be drilled. Drill the holes, cut the frame, and slip the notch over the rails! Bolt-it up and there you have it. ![]()
#19 |
more...
#20 |
gonna ride kinda hard in the back with those tubes between the frame and axle for suspension. lol.
![]() '74 GMC 3/4 TON 2WD LB |
#21 | |
#22 |
kool will the rear kit work on 67-72 also
nickle and dime |
#23 |
86 C10
Coming out nice as always.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
#24 |
cool .............i like the look.
" Never look up a dead dogs butt." ![]() |
#25 |
Until Seventy Times Seven
The Dropmember is a nice piece (like everyone says).
![]() Thanks for showcasing it here. I've followed your thread (http://67-72chevytrucks.com/vboard/s...d.php?t=201898) in the Suspension forum as well as some of the other's Dropmember threads. Most of the information provided centers around the 67-72 crowd. If I may, would you field a few questions about the Dropmember in the 73-87 trucks? 1) I understand that the Dropmember is designed with the use of the Strong Arms LCA, although it will also work with the stock LCA with no modifications necessary. Is it correct to assume that the air bag mounting plates are parallel to each other at ride height? Is this also the case if one uses the stock LCA with, say, a plate (or cup) for the lower air mount? What would the distance between the two parallel mounting surfaces be? I'm wondering if a 224C (instead of a RE7) would maintain the parallel mounting surfaces of the bag's ride height at ~5 1/4". 2) Although the Dropmember relocates the engine a ‘couple of inches’ forward and upward, no modifications are needed to the firewall and tunnel for clearance. Would this be accurate for a SBC as well as a Gen III? 3) Is it possible to retain the geometry of the R&P steering, if the stock outer tie rod ends are shortened and re-threaded? You mentioned in your thread, that both the outer tie rod ends and the R&P, had to be shortened. I'm wondering for these trucks, if only the outer tie rod ends can be shortened without shortening the R&P. BTW, you mentioned that the tracking of the Dropmember setup is narrower where the rotor face to rotor face width on the regular Dropmember is 60". From my measurements, the stock width is ~ 61 5/8” from outer surface of the rotors. Finally, one last request: At ride height, do you know how high the front fender lip is from the ground on the 84? What is the size of the front wheels, drop spindles and front bags? Any information you may provide is appreciated. Thank you.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
