01-19-2008, 02:17 PM | #1 |
Gravity Bleeding Brakes
When you gravuty bleed you brakes do you open up all 4 bleeders and come back in 15 mins or do you do them one at a time?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-19-2008, 07:47 PM | #2 |
Re: Gravity Bleeding Brakes
I do all four at once if the whole system needs bleeding. If I only worked on one end than I just open the two on that end. The fluid can start out pretty fast, so be prepared!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-19-2008, 07:56 PM | #3 |
its all about the +6 inches
if you are gonna walk away, then I'd only do one end at a time.
01-19-2008, 08:44 PM | #4 |
Keepin it runnin!
I havent done it as late, but last time the front seemed to drain out faster. I wouldnt leave it, I'd watch the level in the master cyl.
Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
01-19-2008, 09:19 PM | #5 |
when i replaced my rear frame line i just opened both rear bleeders about 3 mins i had fluid pouring out. after that i did a manual bleed to be sure i got all the air out( i let it drian till i got clear fluid out )
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-19-2008 at 09:20 PM. |
01-20-2008, 01:03 AM | #6 |
Thanks guys I will give that a try. Will let everyone know how it goes.
01-20-2008, 01:45 AM | #7 |
Old Skool Club
If I remember my old school brake bleeding course, you start at the wheel fartherest away from the master cylinder......
Are you sure you can't get anybody to help you by pumping the pedal????? Sure would make it easier to do it right.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-20-2008, 03:21 AM | #8 | |
Fat Fendered Fleetside
But then again, I've always had someone around to pump the pedal, or enticed someone over with some beers...
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
01-20-2008, 04:34 AM | #9 |
Old Skool Club
Beer and Brakes....Brakes and Beer....don't matter which order you put them in, does it? Pump the pedal.....pour a beer.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 01-20-2008 at 04:35 AM. |
01-20-2008, 05:46 AM | #10 |
Yep, as long as both are being emptied out of their respective containers everything should work out.
That is until you fill the Master with beer!
01-20-2008, 06:12 AM | #11 |
i've heard that pumping the pedal just moves the air back and forth in the lines and doesn't really build any pressure or for that matter do you any good at all. the best way is to gravity bleed... furthest to closest, but if you want to use the pedal dont pump it just hold it down while someone else opens the valve then close the valve while the pedal is still down so air doesn't suck back in the lines. then lift the pedal and repeat.
01-20-2008, 06:37 AM | #12 |
the start at the furthest wheel thing is way old school. That was from the days of single reivour master cylinders.
The rear go to one side now, and the front go to the other side of the master cylinder. It doesn't matter if you go left rear or right rear, there is only ONE line going from the front, to the rear axle. Gravity bleeding is perfectly fine, and if you are starting from empty (talking aobut the lines, not the whole system) then it is prefered. Pumping takes a large bubble of air, and turns it into many many little bubbles. Once you have clear clean fluid dribbling out, you can do the old pump and bleed if the pedal doesn't feel good, but most of the times I've gavity bled, it wasn't needed. |
01-20-2008, 07:45 AM | #13 |
heh, I didn't even think about the way the lines run. Makes alot of sense with the more modern master.....so just don't listen to me!
01-20-2008, 11:46 AM | #14 |
Ok its done. I opened them up with a clear tube going to a water bottle. The right rear was ok, left rear was loaded with bubbles. Layed under the truck for 10 mins listening to the planes coming in for a landing, the right front was ok, left front was loaded with bubbles. Sat under there for 15 mins looking at my frame and thinking how much fun I could have on that frame with my grinder and some sanding discs if I had a place to put my cab.
01-20-2008, 05:38 PM | #15 |
did it work good??
01-21-2008, 12:05 AM | #16 |
Andy is absolutely right.....the more air there is in the lines, the better it is to gravity bleed. It does exactly what you need, gets the air out, plus flushes out the old fluid. The old fluid has absorbed water from the air and has caused at least some internal rusting. So it needs replacing anyway.
Pumping just foams up the old stuff. I learned to do it years ago to get a proportioning valve recentered and have prefered it since. The gravity way is a solo thing too, no helper needed. Not every helper is so helpful..... Last edited by LONGHAIR; 01-21-2008 at 12:06 AM. |
01-21-2008, 12:37 AM | #17 |
Old Skool Club
I have a pressure bleeder that I "recovered" from our local dump, back in '75. It still has fluid in it and it still had pressure. Only thing missing is the plate that goes on top of the master cylinder. A man who ran a DX station in our town had died, and his daughter/son-in-law cleaned it out and took what they didn't want to the dump. I think they call it scavenging, but I was saving our environment by taking the scrap out of the ecological food chain.
If you have one of these, it would take gravity bleeding to a little higher plane. LonghornMan brought up a good point, one that I hadn't considered. But the comments about pumping the pedal just moving the air around.....The principle of hydraulics is that you cannot compress a liquid. It's what makes brakes work....that is the pressure in the master cylinder is directed to a wheel, or several of them, to actuate the wheel cylinder or caliper piston. If there is any air in the system, and it doesn't compress, you have reduced pressure at the wheel that is affected. Glad you got it done. Lots of good discussion show up here, and that should be good for those who are new to the hobby and/or are learning about mechanical things. It's good for all of us.
01-21-2008, 12:58 AM | #18 |
As ChevLoRay said, there are alternatives....but they co$t. Pressure systems force the fluid down the lines. There are also vacuum systems that suck the fluid from the bleeder valve end too. Gravity is free....
