Old 01-21-2008, 09:19 AM   #1
68jimmy
68jimmy's Avatar
3rd brake light wiring question
I'm getting ready to setup my cargo light with an led panel to use for a 3rd brake light. My question is where should I attach the 12v side from the brake light switch? And should I just attach a ground wire to the cab?
Thanks in advance....
donovan
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 01-23-2008, 06:57 AM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: 3rd brake light wiring question
In my Camaro I tapped into the existing brake lights, however I don't think this is technically the proper way to do it. When I press the brakes and use a turn signal I notice that the 3rd brake light momentarily goes out, however otherwise it's worked fine for several years.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-23-2008, 07:18 AM   #3
Wrenchbender Ret
The easiest way on a pickup is to tie in with the stop light switch. Use the term. that comes live when the pedal is depressed. Ground the other side of the light.On cars they have kits with diodes. You tie in with the stop lights & the diode prevents it from feeding to the other side. You can use alt. diodes.
Wrenchbender Ret is offline   Reply With Quote
Old 01-23-2008, 07:30 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There's an orange wire, and a white wire on the brake light switch, the orange should be full time 12 volts, the white should be the switched side. Double check before 'tapping into' the wire, but if I'm not mistaken, the white wire will be hot when the brake is applied, and the wire is before the power is split up to left and right, which would be flashing on one side or the other when a turn signal is on.
Tap into said wire, run a new wire up to the new light, and ground the other side of the lamp to the cab.
Old 01-23-2008, 08:42 AM   #5
68jimmy
68jimmy's Avatar
That's exactly the route I took and it works great...
Thanks for all the replies.
donovan
