rocker+22's=?
Well I thought I would post some pics and info about my current project. The truck will be bagged, body dropped, and shaved on 22's!
I started by modifying my lower control arms.I shaved the lip off of the sides, plated the bottom and added a piece of pipe in the middle for the bag to sit in. ![]() ![]() ![]()
Trey Oney |
Re: rocker+22's=?
I then modified the uppers. I didn't really care for the look of them so I tried to make them look a little better by cutting the center out and plating them solid!
Trey Oney |
Re: rocker+22's=?
After finishing the control arms, I did an 1.5" crossmember drop. This is a little more than what you can run with stock steering, but I'm planning on running a rack.
Trey Oney |
Re: rocker+22's=?
With the control arms modified, 3" drop spindles, and an 1.5 crossmember drop, I was an 1 1/8 from laying frame. BUT, that wasn't low enough!
Trey Oney Last edited by bagged01extcab; 01-22-2008 at 09:44 AM. |
Re: rocker+22's=?
So, I removed the cab and welded in some 2x4 tube. This allowed me to cut 2" off the bottom of the frame rail. I then did a 3" z to get the rails to layout!
Trey Oney |
Re: rocker+22's=?
I then reinforced the Z and the area in which i put the tubing and painted the area under the cab.
Trey Oney |
Re: rocker+22's=?
Looks good. Keep the pics coming. Is it just me, or is that front passenger frame rail look a little bent.
Mexican |
#8 | |
Re: rocker+22's=?
Thanks for the compliments! Trey
Trey Oney |
Tot Roddin'
Re: rocker+22's=?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: rocker+22's=?
The next step to get a little lower was to raise the body mounts on the bottom of the cab a 1/2". I would make up for this on the front rails, by lowering them an extra 1/2". I also stripped and painted the bottom of the cab while it was off.
Trey Oney |
Re: rocker+22's=?
After putting the cab back on, I cutt the pinch weld plus about a 1/4" of the rockers off.The front finally had the stance that I wanted! The tires clear the firewall, but I will be tubing it in the future, so that I will be able to turn at ride height.
Trey Oney |
Re: rocker+22's=?
Man thats going to be a whipass truck.. I thought about some 22's for my 81 but, I'am not sure I can pull them off without starting over..
Chickenhouse chopshop 81 rcsb chevy bagged LS1/4l60E(under the knife) 94 ecswb L92 headed LQ9/ 4l80E(waiting to go under the knife) 78 rcsb chevy LQ4/4L80E |
Re: rocker+22's=?
t56 man, I love it.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
Cruzzzn' Vet
Re: rocker+22's=?
#15 |
Re: rocker+22's=?
" Never look up a dead dogs butt." ![]() |
#16 |
Re: rocker+22's=?
#17 |
Re: rocker+22's=?
freakkin awesome work! i love it. damn i should call and order those wheels right now.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() |
#18 |
6.0 powered square
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#19 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: rocker+22's=?
Nice progress, chopped crossmember setup looks REALLY familiar.
You can get away with 1.5" dropped crossmember and stock suspension with some trimming...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#20 |
Re: rocker+22's=?
Man, really nice project and job. I am excited about this, and thanks for taking the time to really detail everything.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
#21 |
Spear and magic helmet!
Re: rocker+22's=?
Does anyone in Texas have a stock truck?
#22 |
Cruzzzn' Vet
Re: rocker+22's=?
#23 |
lucky knuckles
Re: rocker+22's=?
killer job.
#24 |
Re: rocker+22's=?
progress??? Keep us posted. Let my truck live vicariously through yours.
#25 |
Happy to be here
![]() Join Date: Mar 2000
Re: rocker+22's=?
Yeah my 77 is pretty much stock. Stock means the bed isn't cut and the frame isn't Z'ed doesn't it?
