01-22-2008, 03:07 PM | #1 |
81-82 2wd blazer owners I need your help!
I purchased a 87 4wd blazer to convert to 2wd, but this blazer has no axles
under it, so I have no idea where to place my rear axle. I searched all the local junk yards= no blazers! What I need is for somone to crawl under the rear of their blazer and measure from the end of the frame to the center of the rear axle Thanks you guys I realy appreciate your help. Anthony |
01-23-2008, 04:03 AM | #2 |
Re: 81-82 2wd blazer owners I need your help!
Maybe I am not understanding what you asking but the axle should have locating holes on the spring perches to match the locating pins on the springs.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
01-23-2008, 07:22 AM | #3 |
67-72 parts collector,…
If you're building a custom rear suspension,... just center the rear wheel in the wheel opening. Otherwise a stock leafspring will locate the rear housing.
01-23-2008, 11:25 AM | #4 |
www.73-87chevytrucks.com
Just measure 106.5" from the center of the front wheels...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
