Can someone help with a dash pad install?
I've searched the forum and cannot find anything regarding this.
I need to replace my dashpad and I'm trying to remove my old one, but for some reason it won't come loose after I remove the four screws. How else are they attached? Did they glue 'em or something? Any help would be greatly appreciated! ![]() |
Re: Can someone help with a dash pad install?
There are 6 or 7 stamped 3/8" nuts holding the pad on from underneath. I usually pull the glove box and dash to get at them but if you contort enough and have the right tools you can get at them. (If you don't have AC).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
someday it will be done!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
Thanks! I appreciate your help!
![]() Join Date: Jan 2007
Some get lucky and the end bolts are missing (or not installed) - looks like yours are still attached at the ends.
Some people don't use the end bolts when installing it - to make that next time they need to replace it or remove it that much easier... |
Licensed to Thrill!
What they said - plus some patience.
A 1/4" swivel or universal makes the job a lot easier as well. If you are putting a radio, center vent, cluster, ANYTHING else in the dash, put it in after you put the dash pad on. DLB |
Disconnect the neg battery terminal first. You short the hot lead on the headlamp switch if to touch it with the wrench or extension.
The puppy barks but the trucks roll along. |
