Old 01-25-2008, 11:50 PM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Dash issue HELP..Send Photos
Hello,
I bought my truck from a guy trying (and I mean TRYING) to make wood dash bezel, glove box and center dash out of wood, BUT unfortunately I didn't like it and am in the process of trying to figure out what I will do for the center dash area (where the ignition, heater control, air vent, etc is located). It was completely cut out...could you guys send some photos of what you did in the center section of the dash OR make suggestions.
I was thinking of having someone fabricate a piece that I could fasten back in there (I would make a template of an original).
Thanks!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-26-2008, 12:19 AM   #2
suville
suville's Avatar
Re: Dash issue HELP..Send Photos
It would be easier and probably faster to just replace the complete dash, then you can go air or non air. And there has been several for sale here in the parts section.
suville is offline   Reply With Quote
Old 01-26-2008, 12:19 AM   #3
dan42
dan42's Avatar
You can cut out the old dash and put in another one...it's spot welded in, and if you're gonna keep the truck, that's what I'd do.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-26-2008, 01:23 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Without having to pull the windshield to get to the spot welds. Another option is to cut the dash under the pad and then weld in a new front
sneakysnake is offline   Reply With Quote
Old 01-26-2008, 01:28 AM   #5
jkaylor68gmc
jkaylor68gmc's Avatar
thats a good idea, never thought of that.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 01-26-2008, 02:24 AM   #6
Psycho71
Psycho71's Avatar
Find a donor truck. Cut the dash under the pad, remove the bolts on either side, and replace the whole front piece. Then, if you still want wood bezels, just use your glove box door as a pattern for the new gauge bezel, and downsize it just a bit for the glove box door insert. If you find a good dash, you won't need the middle pc at all.
That might be a little more in-depth than you were looking forward too. But it should be a relatively easy project since the dash pad will hide any imperfections that might be left behind.
It sounds like your truck might have been a donor at one time?
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
