its all about the +6 inches
trailer harness Q's
OK, now, keep in mind, my burb isn't here right now.
On the trucks, the harness for the tail lights is under the truck. I had made a plug in piece that plugs in-line with the harness. Flipping through the assembly manual I have sitting in my library (the crapper) I noticed the tail light harness runs up in the roof. Is there an easy way to run the trailer plug? All I need is a 4 flat. I considered plugging in at the firewall where the harness comes out... but again, I am thinking truck terms... I don't *THINK* there is even a plug on the firewall. So does anyone have any ideas? Anyone done this? Anyone UN-done this on there rig? I'll need tail lights if I pull the pop up camper to the meet this summer. |
![]() Join Date: Apr 2005
Re: trailer harness Q's
It runs up in the roof, but you can access it on the drivers side if you pull the cardboard panel out. I think there is a hole that goes through the body underneath. Hope that helps.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
outstanding! Thank you very much!
![]() Join Date: Aug 2003
The only way I've been able to do this is by having wired to each side seperately.
I wired in a second plug in the front so as to run a full length wire harness to the rear on my son's Suburban. I could not bring myself to cut the wires in the rear, (on both sides).
To do this I made up a male/female/male adapter so it was just a matter of plugging it into the wiring in front with a male plug connected to the female end of the front to rear wire which is routed like the trucks. I ended up not cutting any of the factory harnesses with this arrangement. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
are these the same as the truck itself, if so there is a factory plug torwards the rear of the truck for the tailites, they make a kit that will tee right in to the factory plug i had the setup on my 72 i sold last yr
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
The LuvShack Garage
I was thinking the same thing Pug, I put the T on my 67, it must be a Burban thing
the tail light harness runs up in the top of the truck, over the doors instead of along the frame.
Jim, you saying there is a plug on the firewall like on the truck? (again, my burb isn't here, I can't just go look) |
Andy,
I made up an adapter to interrupt the existing wiring that plugs into the pigtail on the under dash harness. The underdash harness is like the trucks with the same plug and pigtail on it. The wires coming from the back were simply plugged into my homemade adapter so that I am able to have the extra plug reach up to the firewall hole, (which is like the trucks) where it plugs into the front to rear harness. I have ended up with a wiring setup that is completely reversible without any mutalation of the Burb wiring. Outside of not wanting to cut any wires, I was a little concerned about the small wires that connect to the taillights/backup and brake lights. The large car hauling trailer that we use has lights on it that may draw too much on the small wires and I did not want to take a chance on it. I can mock up an adapter like I made and take a picture of it if you like. Jim
Andy,
What have you done to your burb? Why is it not with you? You should never let it out of your site it might try to go home. Latr man. |
Jim, I'll probably take a look at mine tomorow... I'm off tomorow and don't have too much planned.
bsharp... I had to leave the burb at the shop. I had problems with my longhorn, had to leave it there to pull the tranny and replace the converter, ended up with 2 vehicles there, and the longhorn just makes more sence to drive this time of year...plus, I don't wanna give the burb any more salt than I need to. It's home now though. |
