Old 01-29-2008, 06:56 AM   #1
djfugate
1970 Chevy Custom C Starting Problems
Hello, I'm new to the message board and I have a problem ---
I just rebuilt the distributor in my 1970 Chevrolet Custom C pickup. At first it started, and then it ran out of gas. I put more gas in it and now it won’t start. I replaced the coil, but now it’s getting very little power from the ignition to the coil and it’s not getting any spark from the coil. I took the coil back and was told it was good. I checked to make sure it was seated properly, but I'm still not getting any spark. Do you have any ideas on what to do next? I have already checked the distributor cap, rotor, fuel filter (new) and they all seem to be working fine.
djfugate is offline   Reply With Quote
Old 01-29-2008, 07:41 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 1970 Chevy Custom C Starting Problems
moved to truck forum.
Welcome to the boards. Can you tell us if it is an HEI, or points type ignition system?
Old 01-29-2008, 07:53 AM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Andy is quick with the fix.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 01-29-2008, 07:57 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
It could be as simple as no ground on the coil.For much in the way of help we need more details on the distributor and ignition.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-29-2008, 11:35 AM   #5
djfugate
It's a point type ignition system
Old 01-29-2008, 03:51 PM   #6
tll74
"Junkyard Dog"
tll74's Avatar
Did it run before you worked on it? Did you remove and reinstall dist.? If the points open and close with proper dewell (28-32), the coil is good, the wire connections are good, and 12 volts at coil....... it has to have spark.
Double check the gap on the points.
Verify 12 volts to the pos.side of coil.
tll74 is offline   Reply With Quote
