01-30-2008, 08:35 AM | #1 |
steering shaft question
I understand what holds the steering column on the truck, but what holds the inner shaft in the column? what keeps if from sliding up and down?
thanks dan |
01-30-2008, 09:45 AM | #2 |
Re: steering shaft question
There is a spring on the bottom which pushes the lower bearing upward, (also, pulling the shaft downward) . The spring is held in place by a large washer which is held in place by the joint on the shaft extension.
On the upper end the steering wheel holds a spring against the turn signal canceler which fits against the upper bearing. So to answer your question two springs reacting against each other hold the shaft in place with the help of the steering wheel and extension shaft. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-31-2008, 11:17 PM | #3 |
Here's an exploded pic from LMC's catalog. The items in the red box hold the shaft together.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
01-31-2008, 11:50 PM | #4 |
Here's a picture of the lower seal - the clip holds the two shafts together. The second picture is the joint underneath the seal.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
02-04-2008, 01:14 PM | #5 |
Great thanks guys. I took the spring off without knowing what it does. Everything fits nice and tight now.
thanks again |
