Old 01-30-2008, 12:04 PM   #1
otsenre
otsenre's Avatar
convert low hump to high
I have this cab out of a 71 cheyenne. Has a low hump with no tunnel bolt on cover. I want to use this cab on a 4x4 frame. Has anyone cut these floors before to be able ti install a 4x4 tunnel cover, and if so, what is best way? ThanksAttachment 332772
Attachment 332773
otsenre is offline   Reply With Quote
Old 01-30-2008, 12:07 PM   #2
Joesjunk
Joesjunk's Avatar
Re: convert low hump to high
Its super easy, you can cut along one of the endentions on the floor. Set your high hump in and mark it, then just cut away!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-30-2008, 12:08 PM   #3
1969k10stepside
I cut mine out with the torch when I used a 2wd cab on my 4wd shortbed chassis.I had the cab off the frame when I did it though.I wouldn't of used the torch if the tranny was in it...I put the 4wd cover on,and sprayed some paint around the outside of it so the bolt holes would be marked...You can tell on the 2wd floor where it needs cut out.
1969k10stepside is offline   Reply With Quote
Old 01-30-2008, 12:30 PM   #4
72swbcamo
Active Member
I used a chisel and just cut in the recessed line on the floor. Make sure you use a good sharp chisel and you will get a nice smooth cut line.
72swbcamo is offline   Reply With Quote
Old 01-30-2008, 12:57 PM   #5
sdkid
Use a sawzall or jigsaw. Will take a little longer. I used an air chisel when I did mine. Lotsa noise.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-30-2008, 02:04 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
Whow, Chisels, Air Chisels, Torches. Yikes. I like how 69k10 used spray paint to mark the holes. Good idea.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
