Old 01-31-2008, 06:20 AM   #1
johnp881
Electronic Distributor
I just place an electronic distributor in My 1970 Chevy c10 it has a 307 small block engine there is only one wire to connect where does it go please help.
Last edited by johnp881; 01-31-2008 at 06:21 AM. Reason: correction in spelling and year
johnp881 is offline   Reply With Quote
Old 01-31-2008, 06:45 AM   #2
70GMCer
70GMCer's Avatar
Re: Electronic Distributor
A constant 12 volt supply when the ignition key is turned on.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-31-2008, 06:55 AM   #3
Luvlegs
Luvlegs's Avatar
make sure it's NOT the power for the original dizzy - that drops the voltage down to like 9V so it didn't burn up the points. I ran a new wire from the fuse block under the dash. Check the FAQ section, the one that has the itemized descriptions - There's also a long post on here with a ton of questions I asked and everyone replied. If I can find it (since I'm suggesting you to try to), I'll post the link....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-31-2008, 07:09 AM   #4
Luvlegs
Luvlegs's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=247956
I think I got it....
nope - here it is:
http://67-72chevytrucks.com/vboard/s...d.php?t=249162
1972 C10 L6 3OTT
