Old 02-05-2008, 07:23 AM   #1
prg machine
prg machine's Avatar
Instrument cluster assembly
well I am at the point that iI am installing my stock instrument cluster... for the light switch and the wiper switch for the 69 configuration, I have a star lock washer on each.... should these go on the inside of the steel dash or on the outside closest to the plastic cluster?????
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 02-05-2008, 07:29 AM   #2
haysonj
haysonj's Avatar
Re: Instrument cluster assembly
I believe they go on the outside at least thats where I put mine
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-05-2008, 08:02 AM   #3
prg machine
sounds like if it worked for you it should work for me..... thanks
383 .040 over
