Old 02-08-2008, 11:51 AM   #1
Jcentsr6
Junior Member
Jcentsr6's Avatar
402 Big block problem
I was speaking with one of my techs at work....he is trying to tune my new carb on the truck today. ( I have never had it running great after doing the cam and lifters and all) Well...we hooked up a vac guage and the engine is only pushing out 4-5 psi. I am told that it should be like 13+....Is this correct? The tech thinks we went to big of a cam for the truck. He says inside the carb that the vac is too low to keep some "block" from working properly (sorry I dont know alot about carbs) so it will not run right. QUESTON: What can I do....
Do I have to replace cam again? Thank for your help
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 02-08-2008, 12:02 PM   #2
CharlieBrown
CharlieBrown's Avatar
Re: 402 Big block problem
what intake/carb combo you running
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 02-08-2008, 12:08 PM   #3
Jcentsr6
Junior Member
Jcentsr6's Avatar
Elelbrock Pro performer intake...and Holley 670 street avenger.
Old 02-08-2008, 12:21 PM   #4
CharlieBrown
well
have had better luck with the elelbrock carbs
they need a divider type intake..other words..not one big hole under the carb for the idle circut to work
on my 383..tried running a holley intake..single hole...no idle vacume...
switched to a the..elelbrock intake and carb..dual plane ..picked up idle vacume..works very well
1972 Surburban 4x4
Old 02-08-2008, 12:24 PM   #5
corn
Which cam?
corn is offline   Reply With Quote
Old 02-08-2008, 12:34 PM   #6
Jcentsr6
Junior Member
Jcentsr6's Avatar
lunati voodoo 262/268 i think...or the 268/276
Old 02-08-2008, 02:15 PM   #7
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Are you running any type of torque/stall convertor with your combo?
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-08-2008, 09:30 PM   #8
Jcentsr6
Junior Member
Jcentsr6's Avatar
NONE. I have not changed anything in that area just yet
Old 02-08-2008, 10:41 PM   #9
My72BB
Can you give us more details on the cam? Need to know the intake/exhaust lift...The duration is 268? or what you had listed...the lift is what really effects the vacuum.
I am going to go out on a limb here...but to have vacuum in the 4 to 5 range??? That is way low. Even a solid lift street cam will normally pull more than that. I would investigate your manifold carb set up...sounds like something was left out or installed wrong?
Pulling the cam is a PIA...hopefully it is something simple like a carb gasket/intake gasket.
My72BB is offline   Reply With Quote
Old 02-09-2008, 03:24 AM   #10
Jcentsr6
Junior Member
Jcentsr6's Avatar
HERE IS WHAT I GOTS!
Lunati Voodoo Cam and Lifter Kits
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 268/ 276, Lift .542/ .554, Chevy, Big Block, Kit
Old 02-08-2008, 10:36 PM   #11
69halfton
69halfton's Avatar
i JUST read about this thing in hotrod.
you can buy more or less an electirc vacuum pump.
it has a switch on it, and when idleing and such it comes on to allow your power breaks to work etc. its deisgned specifically for big cams on the street.
im not sure as to weather it would work in this sitution or not..
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 02-09-2008, 03:19 AM   #12
Jcentsr6
Junior Member
Jcentsr6's Avatar
Thanks..but I dont think that it works for Carb vac pressure....its designed more for power brakes and such.
Old 02-09-2008, 06:55 AM   #13
slammed1
1972 Chevrolet SWB
slammed1's Avatar
The cam is rather small in bigblock terms but big enough to make issues if other things arent addressed. An RV type convertor or a 500-1000 more stall than factory may be needed for this cam. The reason I say this is that for your truck to idle in gear plus run great on the road without detonation,I bet your timing is off. If your timing is dead on (specs) you will probably have to adjust it to a setting that makes the all around idle and WOT performance work together. big Lumpy cams need some type of stall convertor or RV style to help with idle lugging when the timing is set.
Let me see if I can describe this in an example.
I had a 408 small block built with 11.0-1 compression,.488-.288 cam and it worked great with my 67 Impala with 3500 stall and 4.11 gears. I took same engine out and placed it in my 72 truck with stock convertor and 3.08 gears and I had to tailor the timing and carb setting to where it was on the verge of pinging and still idling good enough. Im not saying you need a really loose convertor but a looser than a stock convertor with cams is even recommended with alot of cams on the market......its the cam manufacturers recommendation on most cams " HYDRAULIC: Great for street machines. Use headers and 9:1 compression. In 396-402 use 2500 stall, low gears. Rough idle." (example).
Here is a write up on ignition timng and vacuum settings.
"IGNITION AND VALVE TIMING: A low, 10 to 14 inch, but steady reading indicates faulty ignition or valve timing. Set the ignition timing to the correct recommended spec and everything will probably be OK. You can even set the timing very close to specifications with the vacuum gauge. Adjust the distributor to the highest steady vacuum reading at idle and you'll be close enough to know if that or valve timing is the problem. If you can't get the reading into the "normal" zone by adjusting the distributor then valve timing is the problem. Check and set the ignition timing with a timing light before driving the car, or at least back the timing off a hair and be on the alert for any pre-ignition pinging in the engine. Timing with a vacuum gauge will normally result in timing that is more advanced than what specifications call for. Faulty valve timing is pretty rare in a properly assembled engine, it doesn't change on it's own."
Hope some of this helps.
Old 02-09-2008, 07:06 AM   #14
bryanw1968
bryanw1968's Avatar
You shouldn't be running into any problems with that setup. I have a very similar cam in my SBC and pull 12-14 inches of vacuum at idle. It sounds like you don't have enough timing and or the carbs idle circuit isn't tuned right. Even with an 8:5:1 motor if the rockers are adjusted right and the timing and idle circuit is remotely close you should be at 10 inches of vacuum. You might check to see if your powervalve is good.
Also, I kind of scanned through this post so I hope I'm not repeating anyone but......
I'd pull the powervalve anyway and look at what size it is. A factory powervalve should be 6.5 inches of vacuum. If you are not pulling that much vacuum the powervalve could be fluttering and you may need to go down to a 5.5 or a 4.5. But with your setup I really don't think you should be having any issues. If not any of the above maybe a vacuum leak?
How's the idle/part throttle? Where is your timing? Are you running a vacuum advance distributor and if so how is it hooked up ported vacuum or direct?
bryanw1968 is offline   Reply With Quote
Old 02-09-2008, 07:22 AM   #15
franko72
Franko72
franko72's Avatar
You might have already did this but if not,Try checking your vaccum with a different gauge. Just to rule out a possible faulty test gauge.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 02-10-2008, 05:38 AM   #16
Jcentsr6
Junior Member
Jcentsr6's Avatar
Okay....lets say the timing is out? When installing a gear drive...how hard is it to install wrong? The gear drive was installed at the same time as the cam and lifters....Is it easy to get the timing off with a gear drive? I thought it went on only one way? (One of my techs installed this by the way....not me, as you cal tell) Sould I start there?
Old 02-09-2008, 07:15 AM   #17
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I was kind of wondering myself what the exact problems were.
I found the Lunati site states this about the 268 Cams
"Hydraulic;The most awesome "268" cam ever produced out powers all others!
This High Performance Street cam likes 2400 RPM stall,800 cfm carb,dual
plane intake and headers. Makes unequaled power to 6200 rpm with proper
valve springs. If your looking for a very strong cam with great street manners
for your crate motor this is it."
Old 02-09-2008, 07:21 AM   #18
bryanw1968
bryanw1968's Avatar
You just made me think of something VERY important. Even though that isn't that big of a cam it is considered and "aggressive" profile. AND, if you don't have probably at least 120lbs of installed seat pressure you will bind those springs big time! That happened to me when I had first put my motor together and the machine shop sold me crappy springs. I had really low vacuum until I changed the springs out.
I think this happens more than people realize. They upgrade the cam and have stock heads and just assume that the spring will be fine.
Old 02-10-2008, 06:05 AM   #19
Jcentsr6
Junior Member
Jcentsr6's Avatar
UPDATE: I just checked compression...front two cylinders are at 125psi. Give me some more ideas please. By the way..thanks for all the imput so far
Old 02-10-2008, 06:39 AM   #20
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Please let us help you by telling what exactly your having problems with and what all other mods you have done. The distributor is where your secondary timing is set once the timing is set with the timing set.
Do you have a aftermarket convertor?
Did you replace the valve springs?
Do you have headers?
What exact problems are you having except low vacuum?
Old 02-10-2008, 06:46 AM   #21
Jcentsr6
Junior Member
Jcentsr6's Avatar
Thanks. Sorry. I have
Lunati Cam
Full rollers
Edelbrock pro performer intake
pete jackson gear drive
(org springs)
Holley Street avenger carg 670cfm
Hooker comp headers, Flow master super 44's, Full custom mandrel bent side exit exhaust.
MSD HEI dist...MSD wires, K&N air filter...8an FUEL stainless lines.
Problems. Running rich (plugs look black after 1 day of starting engine to test it)
No POWER...this truck will not spin the rear wheels.
MAIN PROBLEM...NO POWER!...hense I installed all power making parts.
Intermitt back fire and stall.
Old 02-10-2008, 06:51 AM   #22
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Did you degree in the cam when you put it in?
Lunati Voodoo cams are ground with 4 degrees advance in them.
You also need to make sure you vac gague is hooked to the correct outlet. Manifold vac is what you need to look.
125 psi is on the low side for pressure.
A gear drive is easier to install than a timing chain.
Also do a soap test and look for a leaking manifold.
As was said make sure you do not have coil bind and that you are not hitting the valve seals at TDC.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-10-2008, 03:43 PM   #23
clay68c10
clay68c10's Avatar
Sounds like a lot of valve lift for stock springs. I'd run whatever springs Lunati recommends for that cam.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is online now   Reply With Quote
Old 02-13-2008, 02:14 AM   #24
bryanw1968
bryanw1968's Avatar
Like I mentioned earlier, there is a good possibility that those springs are not gonna work with that much lift. Your lack of compression could be that two of the valve springs have already broken. I'd take a look at the top end before I tried to drive it anymore. You could end up dropping a valve ontop of a piston. Just my two cents.
Gooo luck!
Old 02-13-2008, 03:05 AM   #25
kwhite4
Junior Member
kwhite4's Avatar
I had a simular problem with my old 468, cam was in the 574 lift range Crane flat tappet.If your running factory style springs then more than likley thats the problem , I went with Comp honey comb style and Man what a change.
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
