02-08-2008, 11:34 PM | #1 |
chevy truck fan
h-4 headlights ?????
ok all,
i have been doing some thinking about "switching" over to the new style of headlights & the question(s) is why do the "kits" have a wiring harness or why do you need a wiring harness for them?? i have elec. fans as well as relays for my ac unit & i really don't want to add more relays to the system. can you get the new headlights without having to upgrade the wiring on our trucks?? thanks for the replys..... rodstored-72 |
02-09-2008, 01:29 AM | #2 | |
Re: h-4 headlights ?????
Mike
Mike Redpath |
02-09-2008, 01:37 AM | #3 |
Damn Yankee
I agree with Mike; using the supplied voltage from the switch to trip a relay and introduce power from a direct source is much safer
02-09-2008, 02:02 AM | #4 |
Old member
rodstored-72...
Why don't you want to add more relay's? They are the safest way to add accessaries in the older trucks. Most relay's come with a hookup for two add on's and the power wire can be jumped from relay to relay which if tey are mounted close to each other it's a simple thing to add. My two cents worth anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-09-2008, 04:28 AM | #5 |
chevy truck fan
thanks guys,
i thought that was the reason(s) the wire rating, but i didn't know about the switch. my truck is not a daily driver & i am trying to keep the engine bay as clean & simple as possible. i guess i could make a relay "box" & hide all the relays (fans, ac unit & headlights) inside... i dunno i was just wanting a sound board i guess. thanks again guys for the time & help.... on a side note do you guys think adding the lights are a good thing? (asthetic & safety) ???? |
02-09-2008, 06:35 AM | #6 |
its all about the +6 inches
in reality, adding relays to the normal sealed beams is a huge improvement.
02-09-2008, 07:46 AM | #7 |
Old member
I added the headlights a few year's ago and just added the relay's a few weeks ago. Made a big differance at night. Both of them. Once the cold air intake is back in place you can't see none of the wiring.
02-09-2008, 10:56 AM | #8 |
Go for it, the relays are the way to do it. With the relays supplying my H4's, they're almost as bright as my '04 VW headlights.
Asthetically, you can hide a lot of stuff on the core support without it being very visible if you wrap your wiring with black tape or loom and mount things low.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-09-2008, 02:20 PM | #9 |
just get a lmc headlight harnest for the h-4 bulds , no cuttin ,no slpicing
real simple to install |
02-09-2008, 08:36 PM | #10 |
02-10-2008, 02:02 AM | #11 |
sorry but the LMC relay kit is junk.
Mike Redpath |
02-10-2008, 02:18 AM | #12 |
double post
Mike Redpath Last edited by Musclerodz; 02-10-2008 at 02:18 AM. |
02-10-2008, 01:27 PM | #13 |
does anyone have the blue bulbs for their headlights
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
02-11-2008, 01:28 AM | #14 |
20' Daredevil (Ret)
I hate blue bulbs -- I once bought some high $$ Hyper-White blue bulbs (with a money-back guarantee!) and drove home (an hour over the mountain) and promptly removed them. The guy returned my money as promised. I couldn't see squat and later found out why. http://www.danielsternlighting.com/t...e/bad/bad.html
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-11-2008, 01:52 AM | #15 |
Damn Yankee
I have nice dual-function H4 HID kits with clear glass capsules....but we haven't decided to sell them or not....
I know Mike wants my set...LOL |
02-11-2008, 03:21 AM | #16 |
[QUOTE=Tri-ProAutomotive;2571186]I have nice dual-function H4 HID kits with clear glass capsules....but we haven't decided to sell them or not....
Where can I purchase a set of these? |
02-11-2008, 06:14 AM | #17 |
yea where can i get a set of those lmc has the bulbs and i was wondering if anyone had bought them cause i have a set on my xtreme and i want a set for my 69
02-11-2008, 06:20 AM | #18 | |
Damn Yankee
[quote=BustedTruck;2571260]
We thought we could do them for about half what they sell for |
02-12-2008, 12:36 AM | #19 |
Old member
I have a set of blue bulb's in mine now, that I took out of my daughter's Eclipse. I can't tell a differance. Same watt as the clear that came with the tri-bar lights.
02-12-2008, 06:21 AM | #20 | |
Mike
Mike Redpath |
02-12-2008, 09:09 AM | #21 |
Old member
Here are the bulbs I installed in the Tri-Bar light's.
02-12-2008, 12:46 AM | #22 |
Gone Fishing
I just bought a set of the h-4 headlights. ow all I need to do is do the relay install and buy the silverstar headlight bulb ans it will be good to go
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
02-12-2008, 02:00 AM | #23 | |
20' Daredevil (Ret)
Osram, the well-established German lampmaker, sells a line of automotive bulbs they call "Silver Star". These are Osram's top-of-the-range headlamp bulbs, equivalent to Narva RangePower+50, GE Night Hawk, Philips VisionPlus, and Tungsram Megalight Premium. They produce the maximum legal amount of light while staying within legal power consumption limits. They have colorless clear glass. Osram bought the well-established American lampmaker Sylvania in the early 1990s, so Osram is now Sylvania's parent company. Sylvania also sells a line of automotive bulbs they call "Silver Star", but it's not the same product. The Sylvania Silver Stars have blue glass. Light output is of legal levels, but as with all blue-filtered bulbs, you do not get more light from them. The Sylvania SilverStar bulbs have a very short lifetime, because the filament is overdriven to get a legal amount of light despite the blue glass.
02-12-2008, 03:57 AM | #24 | |
Gone Fishing
Thanks for the info. I had a set of them in a sunfire that I drove for 3 years with them in it with no problems
02-12-2008, 12:55 PM | #25 |
20' Daredevil (Ret)
I have heard of a few guys getting decent life from Sylvania Silverstars -- and many more complaining of short bulb life from them...
