02-09-2008, 03:58 PM | #1 |
Toasted Dually Club
Dually Fuse Box needed!
Hey Guy's
My 87 CC Dually had a small short in the running board lights, not bad enough to blow the fuse, just enough to start a small file and melt the area above the lights fuse ... I need and can not find, a fuse box (interior side) with all the wires under the dash, I can't use a painless kit as my truck has TBI with the ecm computer, I'd think that the 88 truck might work also but i not sure .. does anyone have a link to some one that would have one? racing season starting soon and I need to get this fixed up ... Thnx Last edited by N2TRUX; 02-09-2008 at 09:48 PM. |
02-09-2008, 06:05 PM | #2 |
In the Forgotten far North.
Re: Dually Fuse Box needed!
Go to www.car-part.com That is a search engine for wrecking yards nation wide. You simply make your choices from a few drop down menu's, pick your search region, select distance and enter your zip code.
You may or may-not get another screen asking for a bit more info like year interchange desired and/or options depending on the type of part you're looking for. The search results will show listing from the nearest yard to you to the farthest away from you that has what you're looking for with conditions and prices as well. the harness you're looking for should be the same from 87-91 crew cab as well as the suburban and blazer. So if you don't find it for one model try another. But for ease of swapping try to stay as close as possible to your original year. The only things that might be different are the peripherals like interior courtesy lights, power windows/door lock/mirrors and all these can be disconnected from the main fuse block easily.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
02-09-2008, 09:50 PM | #3 |
Happy to be here
Welcome to the forum rickyrqacer. We are always glad to see know members here.
Just so you know, For Sale or Wanted to Buy posts are not allowed unless you are a subscribing member.
02-10-2008, 10:39 AM | #4 |
But why would this apply if someone is asking for info as to where to find a particular part - I.E. aftermarket,dealership wrecking yard? I can seeit if some one says "Does anyone have this or that which I could buy from them, but just asking where to find it?
02-10-2008, 02:20 PM | #5 | |
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
02-10-2008, 03:13 PM | #6 |
Toasted Dually Club
Actually, I think the message is as I wrote it ... I don't blame the owners of this site for their position, It cost them money to run this site and I just signed up. Im more then happy to contribute to the board to help cover some of the expense, and after I get this problem solved, I'll be asking a few more question to get my dually fix'd up even more ...
BTW, I still need a fuse box RR |
02-11-2008, 10:20 AM | #7 |
Would the fuse box in this truck work????
John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. Last edited by Big Blue; 02-25-2011 at 08:55 PM. |
02-12-2008, 02:10 AM | #8 | |
Happy to be here
rickyrqacer I appreciate your understanding as well as your support...
02-10-2008, 01:00 AM | #9 |
Toasted Dually Club
Sorry Mod, I just paid for a subscription for the year ...
02-12-2008, 01:53 AM | #10 |
Sending this to the top.
Need to know by this Wed. on the fuse box.Truck is going for scrap. Cab,front and rear are going unless someone wants them. Make Offer. Fuse box goes to rickyrqacer free, welcome to the group. John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
02-12-2008, 02:02 AM | #11 |
Toasted Dually Club
Big Blue, thanks for the kindness ... to save to some trouble, can you look at the box and see if it looks like my melted one? i'd hate to have you pull it out if it will not work ... what year is that "junker" that you have ? does it have power window?
As for free, thats good, but I gotta atleast pay for shipping and lunch ... RR |
02-12-2008, 02:13 AM | #12 |
There's a guy with 1988 and 89 Suburbans being parted out in 73-87 parts board. These would be fuel injected vehicles of the R or V series. I think the dash harness would be compatible with your 87.
02-12-2008, 05:42 AM | #13 |
rickyrqacer, I was told it is 86,87.
The interior was gutted. Only thing left is the cab,and front/ rear. The box is still in along with the dash harnes and engine harness. I have the light harness. The wheels and tires do not go with the front/rear, org. owner wants them. If all works out then shipping would be fine. John
02-12-2008, 12:32 PM | #14 |
Toasted Dually Club
BB, if it's an 86, if won't be the same, as it's not for TBI with computer ... thanks for the effort though ...
RR Last edited by rickyrqacer; 02-12-2008 at 12:33 PM. |
02-12-2008, 11:39 PM | #15 |
It does have the computer and tbi setup. I will be stopping by my sons work where the truck is located later today. I will photo the fuse box and see if it looks like yours.
John
02-13-2008, 05:30 AM | #16 |
rickyrqacer,
I looked at the fuse box. I am 99.9% sure it is the same one as yours. My son is bringing home the whole truck tonight. I will be pulling the motor and trans out as well as the cab,fuse box and whatever anybody might need. Let me know if you still need the box. JOhn
