02-12-2008, 03:48 AM | #1 |
'71 chevy s.bed/s.side
'71 air cleaner question HELP!!
I am in the process of replacing the thermal switch inside the air cleaner housing, the and vacuum control in the snout. I stripped the old parts out before taking pics. Does anyone have a couple reference pics of the vacuum hoses and the position of the thermal switch? Seems like I read an article some time back about those switches having to be installed a certain way. Also, If that's the case, how does the vacuum hoses run? Which one goes to the carb and which one goes to the vacuum control in the snout?
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
02-16-2008, 07:19 AM | #2 |
Re: '71 air cleaner question HELP!!
TTT anyone have a pic or any info on this/
02-16-2008, 05:34 PM | #3 |
It's a little after 5 this morning and the shop lights are too cold to come on yet (I hate it when I can't sleep) - I'll take some pics in a bit... I believe one side or the other from the AT switch goes to the actuator on the snout and the other one went to..... vacuum on the carb I do believe.... Not sure if it matters which side of the AT switch, it just opens/closes when it hits temp.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
02-16-2008, 09:20 PM | #4 |
UGH - the aircleaner I have is missing the AT sensor - In my manual, it shows the sensor near the snorkle with the "pointier" end aimed at the snorkle. Mine however (72 250) was located across from the snorkle... sooo, that 'ought to help about.... zero. TTT for ya though.
02-16-2008, 11:37 PM | #5 |
Where did you get the replacement parts?
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
02-17-2008, 05:59 AM | #6 |
Luvlegs, thanks for, well, nothing!! LOL!!
cruiserman, I purchased the sensor, the small piece that the two vacuum hoses connect to, from NAPA. I also purchased the vacuum piece that sits on top the snorkel from NAPA. I believe that part is called a vacuum door motor, or a vacuum motor.
02-17-2008, 06:56 PM | #7 |
I woke up swinging there yesterday morning - pretty much fizzled out by 8....
02-17-2008, 06:09 AM | #8 |
Got pn#s?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
02-17-2008, 10:47 AM | #9 |
Yes, part numbers would be nice, but I'll try NAPA tomorrow. I was told by the dealer they are no longer stocked. I'm used to buying Land Cruiser parts, and if Toyota doesn't have it, it doesn't exist. I forgot that GM sells nothing for older vehicles.
02-17-2008, 07:20 PM | #10 |
cruiserman, I have bought several pieces for my '71 from GM recently. There's alot that has been discontinued, but if you have the old part numbers sometimes they can get it.
Try these NAPA #'s. Not sure if they are the ones for these parts, but out of all my receipts, I believe I have narrowed it down to these. 2-2202 sensor -(inside the air cleaner housing-the 2 vacuum hoses connect to this piece) 22259 - motor- sits on top of the snorkle Good luck!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! Last edited by Botietruck; 02-17-2008 at 07:20 PM. |
02-19-2008, 03:11 AM | #11 |
Thanks for the part numbers.
02-17-2008, 07:22 PM | #12 |
Luvlegs, I noticed last night that someone had a 6 cyl. air cleaner for sale on the board and had posted the pics...just what I needed! Did you get that air cleaner set up completed that you were working on several weeks ago?
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! Last edited by Botietruck; 02-17-2008 at 07:23 PM. |
02-17-2008, 07:59 PM | #13 |
yepper - let me see if I can find some pics.... (mine is an offset setup to clear the brake booster)
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 02-17-2008 at 07:59 PM. |
02-17-2008, 08:06 PM | #14 |
I didn't have the hose on from the carb riser to the valve cover but you can get an idea... (seems like everything I add on is black.... )
02-17-2008, 10:25 PM | #15 |
Luvlegs, I found the correct size PCV hose at the Caterpillar dealer where I work. I have the Cat p/n if you are interested. I believe it's made by Gates, and it is PCV hose. If you are interested and can't get it locally, let me know. I paid about $6.00 for mine. Do you have a Gregory Poole Cat dealer near you?
02-18-2008, 07:46 PM | #16 |
I found a piece of hose in my shop - I think I picked it up when I cleaned out a maintenance shop in a mill that was closing.... I think it's just heater hose - it works and looks good though. Are you looking for an offset aircleaner or the regular kind?
02-18-2008, 11:24 PM | #17 |
I have the offset air cleaner setup, just have not had time to install it...not that I need it right now. The truck is several months away from being ready for the road.
