Repinning connector for 90-91 burb electric speedo
Anyone repin the connector on back of cluster and swap in 90-91 burb/blazer cluster with electric speedo?
I got a "diagram" from another forum from a guy that did his 87, I think my wires are different than what he has down for his 87, at least that's what the factory wiring manual says... I have 2 good 90 burb clusters. Just want to make sure I repin them right. My truck is an 86. This is what he gave me... 87 1 - high beam indicator 2 - ign. power 3 - ground 4 - ign. power 5 - oil signal 6 - ign. power 7 - not used 8 - not used 9 - temp signal ---------------- 10 - ign. power 11 - left turn signal 12 - right turn signal 13 - seat belt indicator 14 - 4x4 signal 15 - SES light 16 - ign. power 17 - parking brake 18 - fuel level 1991 suburban 1 - high beam indicator 2 - ground 3 - oil signal 4 - ign. power 5 - dont use 6 - dont use 7 - dont use 8 - temp signal 9 - ign. power ------------------ 10 - left turn signal 11 - right turn signal 12 - 4x4 signal 13 - seat belt signal 14 - fuel level 15 - parking brake 16 - SES light 17 - ign. power 18 - VSS input There just seem to be a couple "off" compared to my wiring manual. Or maybe I am just looking at it wrong. If you've done it, post up. If you see anything not right, let me know. I guess determining #1-18 is looking at the front of connector(not rear w/ wires) #1 is on bottom right, top right is #9, top left is #10, bottom left is #18 Is this correct? thx
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#2 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Repinning connector for 90-91 burb electric speedo
marked 1-9,top to bottom on the left side of it(closest to door) and 10-18,bottom to top on the opposite side of it. DAYTIME RUNNING LIGHT
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 02-12-2008 at 04:59 PM. |
On your '87 model the gauge illumination wire SHOULD be grey in color.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
thx...
I will pull the connector off one of the burb clusters and put my glasses on so I can see...
